Rattling noise from driver's side seat belt on uneven roads
Results 1 to 15 of 15
Thread: Rattling noise from driver's side seat belt on uneven roads
    Sep 2014
    Bc
    Has anyone had this problem of seat belt rattling coming from the catch, when it is on uneven roads?
    Apr 2014
    MD
    1,043
    155
    255
    Re: Rattling noise from driver's side seat belt on uneven roads
    Not yet, but the cleverest solution I've ever seen was on my Miata, where they had a little plastic clip on the interior, just behind the door opening, into which you inserted the buckle. Handy and easy for the passenger to grab the seatbellt -- and no rattle. Might be an interesting retrofit for a Porsche.
    The Land of No-Roof cars!
    2015 Base Boxster, Guards Red/beige, sport suspension/seats/steering wheel
    2007 Honda S2000, New Formula Red
    1964 Sunbeam Tiger, White with Guards Red stripes.
    May 2014
    796
    225
    245
    Gamertag: radonculousmd
    Quote Originally Posted by Am Brose View Post
    I have the same problem
    964 RS America
    981 Boxster S
    981 GT4
    Apr 2013
    I had this rattle issue on the unoccupied passenger side but moving the seat forward a little solved it. Not sure if that is what the thread relate too.
    Sep 2014
    Bc
    Thank you guys. I think the noise was caused by the metal parts moving in the buckle when seat belt is on but it did not happen on passengers side.
    Sep 2014
    Bc
    Thanks. I have moved the clip near the buckle to tighten the seat belt but it does not seem to improve. Will try solve this when bringing this back for service.
    Nov 2013
    florida
    49
    Same problem. I just always buckle the passenger seat belt when not occupied.
    Jul 2014
    I having the same problems on the driver side of my new Cayman GTS. Any updates. Planning to take it in next week.
    2,573
    570
    688
    Mine almost makes a buzzing sound. I have found only one road where it does this and it is just the right (wrong?) road surface that sets it up. It is of such short duration and so small an occurrence that I have not addressed it.
    May 2013
    332
    347
    120
    Any news on the culprit? I have clicking noise/rattle in the center dash too. That one is bad and has to fixed. Sounds like 2 turn signals going at once!
    2015 Cayman GTS
    White / Black / Platinum / PDK / PTV / X73
    www.porsche-code.com/PFRUHWW7
    Dec 2013
    Burbs of Philly
    Any solutions to this issue?
    This just started happening to mine. Clinking during acceleration/braking.
    Feb 2013
    107
    49
    On my 2016 CS, the problem was simply my plastic seat belt latch rubbing on the seat. Easy test is to just put a cloth between the two - if the sound goes away, that's the problem. Solution is to get some adhesive felt and affix it to the latch.
    On the passenger side, the buckle can bump on the plastic molding. If you rarely have a passenger, you can just keep that belt latched in.
    Bern
    2016 Cayman S
    Track at Thunderhill, Laguna Seca, Buttonwillow
    Dec 2013
    Burbs of Philly
    Quote Originally Posted by bernb6 View Post
    Bern
    Thanks Bern. But mine is rattling internally and it only seems to happen with the seat belt buckled in and only on the drivers side. It feels like something is loose in in there. Buckle still works fine.
    Mar 2018
    Chevy Chase, MD
    I find that pulling the belt snug at the lap puts some tension on the buckle and eliminates most of the creaking coming from the latch.
    May 2017
    Germany
    39
    I always just slide the seat buckle all the way up and flip it up as it is against the seat belt outlet trim.
    2014 Porsche Cayman S - MT/Chrono/X73/PSE/PTV
    2004 Mazda RX-8 (beater/winter)
    2011 Chevy Camaro SS (sold)
  18. Remove Advertisements
  1. noise from drivers side with roof down
    By nickafc1903 in forum 981 Cayman and Boxster Problems and Complaints
    Last Post: 02-12-2016, 03:21 PM
  2. Cayman S Noise from driver side floor
    By haus in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 01-25-2014, 10:31 AM
  3. Rattle Noise from Speakers
    By spourreza in forum 987 Cayman and Boxster Electronics
    Last Post: 08-13-2009, 07:38 PM
  4. Ticking noise from driver side tail light
    By golfer in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 02-21-2009, 08:23 PM
  5. Noise from driver side rear
    By Richey50 in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 04-03-2008, 01:31 AM
