PSM Failure followed by PSM Loss on track day - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: PSM Failure followed by PSM Loss on track day
  1. #21
    Jul 2018
    Oregon
    86
    35
    Re: PSM Failure followed by PSM Loss on track day
    Quote Originally Posted by kiryu View Post
    Hi guys after I replaced the ignition coil #6 and cleared the codes, all was well for 3 weeks. Did 500-600 miles or so (including a long 4 hr drive). Today the same codes came back. Cylinder #6 - soft shut down, misfire, check engine light etc. causing PSM loss and start/stop activation disabled. It also drove rough and was worse than before
    Appears to be only happening at cylinder #6 though. Could it be the spark plugs that i need to tackle next? any thoughts?
    Are you sure you did cylinder #6? I've seen conflicting info online about which cylinder is which on our cars. When I did mine, I just replaced all 6 coils because I assumed if one was going, the rest would follow.
  3. #22
    Jan 2015
    57
    Quote Originally Posted by johanmalay View Post
    Good point. Is #6 the one that's closest to the driver, on the driver side? That's the one I replaced. If that's not #6 then lmao, I would have to do the other side.
    I dont think the code reader would be pointing to the wrong cylinder, it's all communicating with the car's ECU. All the codes i have seen before and after the install is pointing to #6 only
    2013 Boxster - pdk,k&n
    2012 R8 V10
    2011 458
    2015 GT3
    SOLD 07 IS350 03 G35 01 3.2CL 89 Supra
  4. #23
    Jul 2018
    Oregon
    86
    35
    I honestly never found a good answer. I don't know. Mine also pointed to #6... but which is 6? For all I know, it could be any one of the 4 corners of the engine depending on how you look at it or where you start counting from. I even spent a bit of time trying to find the info in the OEM service manual, no luck ( I probably didn't look hard enough ).
  6. #24
    Jan 2015
    57
    good point, i probably replaced the wrong coil...hahahaha. let me try the other corners and see. Thanks!!
    2012 R8 V10
    2011 458
    2015 GT3
  7. #25
    Jan 2014
    New jersey
    Seems similar to what I had with my 13BS. Ultimately changed coil packs and spark plugs between cylinders. Error codes persisted. Next step flow down and compression test which were OK. Bottom line keeper clip failed and valve not closing when expected. Engine dropped, heads off, and many $$$$ later.
  8. #26
    Jan 2015
    57
    Quote Originally Posted by llan981 View Post
    holy crap. that's scary to hear. I thought these germans are bulletproof comparing to bmw or benz... that kinda failure shouldnt be happening at 35k miles oh my
    2012 R8 V10
    2011 458
    2015 GT3
  9. #27
    Jan 2015
    57
    So my #6 was misfiring pretty bad, the car ran rough and has no power at pickup. I took's Johanmalay's point and instead changed the coil on the driver's side furthest away from the driver (nearest to the exhaust and was very easy to replace), the car runs fine, cleared codes and they havent came back yet. So at least in my case, #6 is the one on the driver's side, furthest away from the driver. Apparently I changed out #4 last time and not #6 LOL. It's pretty amazing the faulty #6 did another 500 miles before giving up including a long drive, so they do give you warning signs before going out. Thanks all!
    2012 R8 V10
    2011 458
    2015 GT3
  10. Remove Advertisements
  1. PSM failure, ABS failure both lit up today
    By looper_1234 in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 03-15-2016, 05:26 PM
  2. Wheel Distribution ( ABS failure - PSM failure )
    By FrankinCayman in forum 987 Cayman and Boxster Chat
    Last Post: 04-10-2013, 01:25 PM
  3. PSM failure, ABS failure
    By olivertan in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 12-16-2012, 05:29 AM
  4. Cayman Dies in 2012, followed by Carrera GT
    By K-Man S in forum Automotive Off Topic
    Last Post: 11-17-2009, 06:49 PM
  5. Hot lap on a 997S followed by Carrera GT
    By DMN987S in forum Automotive Off Topic
    Last Post: 06-18-2009, 05:57 PM
