Rattling noise from engine bay while in gear and coasting
Results 1 to 7 of 7
Thread: Rattling noise from engine bay while in gear and coasting
    Feb 2016
    NC
    194
    27
    I noticed this the other day when driving home from work. After the car was hot, it started making a quiet rattling noise from behind the firewall around the center console when in gear and coasting. Didn't seem to be speed or RPM dependent, nor did it matter what gear I was in. Disappears after going below about 25mph. I checked both fans for debris, but didn't see any.
    Didn't notice it when starting up the car, but once warmed up, the sound returned. What could this be?
    Mar 2009
    2,170
    835
    619
    Re: Rattling noise from engine bay while in gear and coasting
    I'd guess bearings in one or more of the drive belt guide rollers or water pump. Neither issue particularly difficult or expensive to resolve. You'll need to remove the engine cover behind your seats where you most likely can zero in on the source. Good luck.
    Feb 2016
    NC
    194
    27
    Quote Originally Posted by Budman View Post
    Thanks. I'm still under warranty for... 3 months? I'll get it checked out.
    Jul 2019
    When coasting and you hear the noise, shift to neutral. Any change? Rev the engine while in neutral. Any change?
    Oct 2016
    TX
    260
    54
    Feb 2016
    NC
    194
    27
    Doesn't seem to occur when I'm standing still oddly. I need to do more testing.
    Feb 2016
    NC
    194
    27
    No sound when clutch is depressed or when pulled out of gear. It's only when decelerating in gear, regardless of gear, after the engine warms up. I guess I'll take it in and let them check it out.
    Maybe the throttle body is flapping around a bit?
  10. Remove Advertisements
