981 radiator fan heads-up...
Results 1 to 6 of 6
Thread: 981 radiator fan heads-up...
    May 2011
    NJ
    478
    103
    A bit of a warning for 981 owners regarding the 2 front fans.
    Had my 55k mile 2013BB in for unrelated repair last month and was informed that I had an inoperative radiator fan. Though disappointed, I was not shocked, as I have experienced fan failure on my 986 in the past. I asked the dealer if he was sure, and he said there was a tripped code and the fan was seized. This was different than my 986 experience.
    So when I got the car back, I tried to turn the blade and sure enough it would not move. So since fan removal requires removal of the nose and dropping the radiator down, I thought I would further inspect it by removing the inner wheel well cover. After that, I discovered that the fan motor was jammed by tiny stones that worked their way into the motor. I worked the blade around until it started to release and spit out pebbles.
    I then spent about an hour spinning the fan by hand and blowing around the motor with compressed air until I got all of the rocks out. I started the car and ran the AC on max, which runs the fans, and confirmed that no more rocks were in the motor. So far it has been working perfectly for a month. Didn't blow any fuses or cause any damage. Maybe the fan will fail prematurely in the future, but right now no problems.
    Regarding why this may have happened, I am one of those guys that keeps the HVAC system turned off most of the time. The fans almost never get a chance to run. I believe this allows time for small rocks that are bouncing around on the street/hwy to work their way into the motor. Screens in front of the radiators probably won't help much since these pebbles are so small. Though I still generally don't use the HVAC when driving unless needed, I now run it a few minutes every time I take the car out hoping this will help keep out/work out any pebbles that may be working their way toward the fan motor.
    So, good news is no damage or replacement required. But I would watch for this issue if you have a 981.
    Aug 2016
    fl
    729
    121
    Thanks for the heads up.
    It’s hot AF here so I run the AC all of the time.
    Jul 2013
    N/A
    801
    406
    277
    Re: 981 radiator fan heads-up...
    I never run the AC, so thanks for this. I’ll let it fly tomorrow and at least once a week to clean the fans out (or try to).
    Mar 2016
    34,155
    Related but not the same cause, I was occasionally hearing a noise from the front wheel well and it turned out to be some track rubber that had wedged into the plastic grill work occasionally making contact.
    Jun 2019
    I appreciate this heads-up
    "I started the car and ran the AC on max, which runs the fans. . ." -- I tend not to use the A/C myself, so based on this info I'll start running A/C Max for a bit.
    Glad to hear that you investigated, solved the issue, and passed along your experience.
    2014 Cayman S (6MT) triple black
    2017 Macan Volcano Grey Metallic w/ nav, pano roof &c
    Jul 2014
    england
    40
    The open front bumper / fender design where the air conditioning condensor radiators sit is fine for allowing air flow to a maximum but awful for allowing crap to wreck the radiators. I have changed all the condensors on my previous 986 and 987 but not anymore on the 981. I use plastic open black mesh to stop any grit or debris. This is placed behind the horizontal fins infront of the rads.its not brilliant but no more air con problems ...ever
  9. Remove Advertisements
