ECU, PSM, Auto Start/Stop Fail Symptoms --> Bad Coil
Results 1 to 6 of 6
Thread: ECU, PSM, Auto Start/Stop Fail Symptoms --> Bad Coil
    Oct 2016
    TX
    235
    49
    Just wanted to give a head's up to the 981 crowd about the failure modes for coils.
    I was driving along on my daily commute and about 20-min in, all hell broke loose. It started with a PSM fail message, followed a few seconds afterward by an ECU fault and Auto Start/Stop fail message. Car started running like crap - felt like I was driving over serrated pavement. I limped on to work and set on to figure out what to do next.
    The first thing that popped into my mind was maybe a faulty battery - it is 4 years old and it's consistently in the high 90's to 100's in Texas this time of year - perfect recipe for a failed battery. I've heard these symptoms are typical for that. I pulled into the lot at work and turned off the car and tried a restart - still running like crap and the fail messages reappeared.
    I decided to wait until lunch, let the car cool, and maybe the problem would go away temporarily for me to get home and pull the codes. At lunch, the car started right up. Check engine light was still on, but the car was running fine. I decided to give it a try to make it home to pull the codes. About the same thing happened. It was great on the freeway, but after about 20 mins as I slowed down at my exit, the warning messages re-appeared and engine started running like crap again.
    Limped home the remaining 2 miles and pulled out the code reader. A lot of codes - several PSM comm fail messages, cyl 5 misfire, cyl 5 soft shutdown - now I knew why it was running lousy - it was only using 5 cylinders. I don't have the code readout in front of me - I'll add the full set of codes I pulled later.
    I had changed the plugs about 8K miles ago, so I was fairly sure that wasn't the problem. My next guess was the coil. I had hoped that Porsche had perfected the coil-on-plug design since the crappy coils on my 2004 Mazda 6, but alas, I guess not. I'd put quite a few high-temp track days on the car this spring, so I'm guessing that contributed to the (pre-mature?) failure.
    Long story short - cylinder 5 coil.
    Looks like they have redesigned the coil since the late-2013 production run for my car. Latest coil is a rev-07. I'll probably plan to replace the full set later this fall when it cools off. I was talking to another 981BS owner and he indicated PCNA replaced his entire set under warranty after a second coil failure. So, it sounds like this may be a common problem.
    Apr 2014
    Atlanta GA
    216
    52
    Re: ECU, PSM, Auto Start/Stop Fail Symptoms --> Bad Coil
    I replaced all my coils on my 987.2 this past winter after 1 went bad. The old coils were revision 4 and replaced with revision 7. I don't know if the 981 and 987.2 use the same coils. I doubt it.
    Feb 2018
    UK
    Two weeks ago I had exactly the same problem on my 2014 Cayman GTS. The coil for cylinder 5 was replaced under warranty. This was the next day after a full service from my Porsche centre, which included replacing all the spark plugs.
    Mar 2014
    851
    17
    178
    I had that sort of thing in January. My description was it sounded like an American V8, horrible vibrations, and lots of different lights on. I limped the mile into work, then got the car flat-bedded to the dealer. They replaced the coil under warranty. Everything's been fine since.
    Ours was build July of 2015, and the warranty is up at the end of August, I should get him looked at.
    2015 Cayman S, Sapphire Blue.
    May 2015
    CO
    78
    47
    Why is your warranty up if the car was built in July 2015?
    You should still have another full year to go.
    4 years/50k miles.
    I received mine June of 2015, and the time doesn't run out until June 2019, but I will hit the 50k mark later this year, easily (just under 41k miles right now).
    BC.
    Mar 2014
    851
    17
    178
    Quote Originally Posted by Bladecutter View Post
    Ooops, it was built in 2014, it's a 2015 (a very early example).
  9. Remove Advertisements
  1. Cruise Control, PSM/STOP and START Function Failure
    By light speed in forum 981 Cayman and Boxster Problems and Complaints
    Last Post: 07-02-2013, 05:42 AM
  2. snow, PSM fail, ABS fail and flashing dash
    By mike_balt in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 12-26-2012, 02:59 PM
  3. Engine Overheated - HELP>>>>>
    By arnold in forum 987 Cayman and Boxster Chat
    Last Post: 09-09-2012, 03:36 PM
  4. HAPPY THANKSGIVING!!! 2 Day Sale >>>>>
    By Chris(NJ) in forum Site Vendors & Sponsors
    Last Post: 11-23-2007, 12:54 PM
  5. 7 Speed DSG HERE AT LAST>>>>>>>>>>>
    By Mega in forum Automotive Off Topic
    Last Post: 05-21-2007, 04:25 PM
