Minimum oil level warning
Results 1 to 2 of 2
Thread: Minimum oil level warning
    Nov 2006
    NJ
    441
    45
    Last week I was driving my CGTS and when I pulled out of a parking lot with a very steep uphill incline, the bottom of the car made a ‘clunk’. I wasn’t happy but I assumed it was just the bellypan. About 5 miles up the road a warning light came on saying that I had reached the minimum oil level. I immediately pulled over and shut down the car. I checked underneath to make certain that I didn’t damage something more serious but saw nothing.
    I added a quart of oil to the car, and started it up, but I still got the same warning. I then let it sit for a bit and checked the oil. It said it was still low (below minimum). I added another quart of oil. Everything seemed ok, but about 10 min later I got another warning that I had overfilled the oil! How can that be? I’m going to do an oil change next weekend anyway, but do you think thAt the oil sensor could have got jarred on some way to make it act strange?
    Here are the warnings:
    2016 Cayman GTS - PTS Birch Green, 6MT, X73, PTV
    Past - 2013 911S; 2008 Cayman S Sport; 2007 Cayman S; 2006 Cayman S
    Jul 2013
    N/A
    717
    346
    253
    Re: Minimum oil level warning
    Unfortunately the oil level indicator is not immediate. It’s kind of an insult to injury kind of thing on top of not having a dipstick...
    After you add oil you need to close the hatch, start the car and then warm up the oil by driving around for a while. Then when the oil is up to temp (90c) you shut the car down, wait for a minute and then turn the key half on and check it.
    What happened is your first reading was meaningless - it was just repeating what it knew from before. The second liter overfilled it.
    I think it is about a liter between the bottom measurement and the top. I would have started by adding a half liter and then checking it as above.
  4. Remove Advertisements
  1. Oil level above maximum level - Very Cold Temps
    By darcus in forum 981 Cayman and Boxster Problems and Complaints
    Last Post: 02-06-2019, 08:36 PM
  2. done oil change and shows the oil level above max
    By kk123 in forum Club 911 - General Discussion
    Last Post: 10-10-2018, 03:01 PM
  3. Oil Change Last night - Fault Oil Level Measure - service necessary
    By JacobToronto in forum 981 DIY Discussion
    Last Post: 09-16-2018, 09:53 PM
  4. Oil level indicator at minimum after 1st service?
    By lusocayman in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 05-29-2010, 05:31 AM
  5. Is it possible to check the oil? No, not the oil level…
    By downshift in forum 987 Cayman and Boxster Chat
    Last Post: 03-26-2010, 05:37 PM
