Need help with my iCarsoft scan tool - resetting airbag light
Results 1 to 11 of 11
Thread: Need help with my iCarsoft scan tool - resetting airbag light
    Sep 2009
    AL
    1,115
    143
    33
    I've tried everything I can think of to get the airbag light off, no deal. It's not easy understanding the diagnostic process on my Microsoft scan tool, so I may not be doing what I should to reset it. Any help will be appreciated.
    Sep 2009
    AL
    1,115
    143
    33
    Re: Need help with my iCarsoft scan tool - resetting airbag light
    Meant to mention, 2016 Cayman GTS.
    Oct 2016
    I can tell you it won't be easy if not impossible. If you installed a 'race seat' and removed the Porsche harness the system doesn't 'see' the seat's air bag termination and as such triggers the air bag light. As far as I know none of the simple OBD tools or even the Durametric will override the air bag error. A Porsche PIWIS can do it but dealers and independents won't defeat it due to liability reasons.
    I've tried resistive network simulators and none were successful. I've learned to live with and/or ignore the little red air bag icon.
    For what it's worth the rest of the air bags are fully functional even w/ the air bag 'warning' light on.
    Good luck . .
    MI
    6,449
    439
    1703
    how many wires are going from the censor to the car? 2, 3?
    There is always a little black sticker. Amazon sells them.
    triple black Boxster 981S MT, custom front and rear bumpers, custom exhaust, WD808 rims
    Wireless Charger/Magnetic Mount
    live at 100%
    Memory Module
    Universal Phone Mount, Cup Holder, and more at
    Sep 2009
    AL
    1,115
    143
    33
    Quote Originally Posted by AP911 View Post
    Good luck . .
    I failed to mention the reason the airbag light is on. I pulled my steering wheel several times to install different versions of the adapter Li Paul was testing for the bluetooth Mode switch feature he developed. I always took the battery cable off and never switched the ignition on while doing this, but somewhere along the line the light came on and has been on ever since. I'm used to it, but I got the iCarsoft unit (PORII) to reset the service reminders and hoped it would also turn off the light. I tried every way I could see on the scan tool to do it, but may have missed one, just asking if it can be done. No wires were pulled except the ones in the steering wheel, and the battery cable was always disconnected while I did it. I got to where I could pull the airbag and install a new adapter, reinstall the bag and have everything buttoned up in about 10 minutes(not counting the 20-30 minutes I waited after removing the negative terminal cable of the battery).
    May 2015
    505
    90
    I've read on P-9 that once the airbag light is on, only the dealer can shut it off with PIWIS. I'm not an expert though.
    Oh - I was wrong- https://www.planet-9.com/987-cayman-...t=airbag+light
    av8bpilot
    said he reset the airbag light with icarsoft.Maybe reach out to him.said he reset the airbag light with icarsoft. Maybe reach out to him.
    2014 Boxster Rhodium Silver/Black, PDK, 19" Boxster S wheels, PDLS, ParkAssist, CDR Plus, Convenience, X73 Rear Sway Bar, Inflatable lumbar support, vinyl wrapped interior trim
    Sep 2009
    AL
    1,115
    143
    33
    I got it off. It might have been from my first attempt, I just needed to start the car twice. I just finished scanning again and used the "clear fault codes" option, but in any case the light is off now. ICarsoft is neat! I found a lot of things that I have no idea of the meaning, but it appears to be as powerful as the Durametric. Thanks for the replies.
    Sep 2015
    Atlanta GA
    1,016
    81
    287
    Quote Originally Posted by mitch48 View Post
    Just be careful resetting codes especially if you are about to be due any emissions testing. Clearing them resets all of the needed emissions ready test data and your car will fail unless it has had the time to see all of the many different situations required to get all of the internal testing back to the ready state again. This can take a lot of miles and a long time if your car is not a daily driver. The good news is the device itself can also show you if anything is in the not ready state so you dont waste your money testing for no reason.
    Sep 2009
    AL
    1,115
    143
    33
    My state doesn't require any type of inspections, so that's not a worry for me. I only reset the airbag anyway, but its cool I guess to have so much info, if I only had sense enough to interpret it!
    MI
    6,449
    439
    1703
    What is exact name of that icarsoft device? Or can you give link to amazon?
    live at 100%
    Memory Module
    Sep 2009
    AL
    1,115
    143
    33
    Its the iCarsoft POR II, here's the link: https://www.amazon.com/iCarsoft-Diag...g%2C167&sr=1-4
    I had bought a Launch Creader but never could get it to work, so sold it and got the iCarsoft one. BTW, I did an update to it before trying to reset the airbag light, but I don't know if that helped or not. Anyway, it worked. I went to YouTube to look at some vids and one suggested that after resetting the light you had to start the car twice before the light would extinguish, which was my experience.
  14. Remove Advertisements
  1. Need help with my iCarsoft scan tool
    By mitch48 in forum 981 Cayman and Boxster Service and Tech
    Last Post: 03-20-2019, 12:08 PM
  2. ICarsoft POR II
    By JamesBond in forum 987 Cayman and Boxster Service and Tech
    Last Post: 10-31-2018, 08:58 AM
  3. What Scan tool works with newer porsche
    By dchughes in forum 987 Cayman and Boxster Service and Tech
    Last Post: 11-20-2012, 11:26 AM
  4. Scan tool/code checker/reader ?
    By bldn10 in forum 987 Cayman and Boxster Electronics
    Last Post: 06-04-2012, 02:20 PM
