Tail Light Removal
Results 1 to 16 of 16
Thread: Tail Light Removal
    Feb 2013
    Sioux Falls, South Dakota
    69
    Tail Light Removal
    I removed my tail light assembly today while searching for the backup light wire. It didn't occur to me until I had the light assembly out that the backup light is the clear LED light center mounted under the spoiler.
    Here are the pictures I took.
    One bolt hold the light in place. It is behind a rubber plug.
    This is the tail light cavity:
    The bottom of the light. Note the two tabs and the push pin at the rear (front of photo)
    As Orangecrush stated in his posting the light assembly pulls straight out once the bolt is removed. However, you do need a tool (well padded) hooked around the back of the light assembly to pull it out.
    Bruce
    Sep 2013
    Re: Tail Light Removal
    So, you can't pull it out by hand? What tool would you suggest?
    BC
    4,827
    1066
    1181
    Quote Originally Posted by mavjr99 View Post
    Couldn't you just push on the assembly from the bolt hole to start it moving out?
    Could you also describe where exactly that bolt is?
    2013 Boxster 981-S
    2006 Boxster Base
    Apr 2012
    N/A
    69
    The Porsche tech notes say to remove the rubber grommet in the rear wheel arch and push the 'push-pin' from there.
    Agate Grey Boxster S, Black Roof and Carrera Red Interior
    Options: PCM inc tv, tel & voice cntl, 20" Carrera Classics with Coloured Crests, TPM, Electric mirrors, Electric Heated/Ventilated Seats with Crests, BOSE, PDK, Sports Design Wheel, Sport Chrono, Park Assist, Climate, Sports Exhaust, PTV, Cruise, PDLS, PASM, Rain Sensor, Wind Deflector, Lighting Package, Silver Belts and Illuminated Door Sills
    Feb 2009
    New York
    942
    658
    223
    Quote Originally Posted by wizard263789 View Post
    Easier said then done...
    Thomas
    2013 Boxster
    2008 Cayman S - gone, but never forgotten...
    Apr 2012
    N/A
    69
    With a screwdriver if that helps The text says :-
    Insert a screwdriver through the opening and position it on the removal surface of the light. Press the light out of the ball socket using a levering motion'
    Seems like the other method detailed above works if not
    Quote Originally Posted by Finally @ 57 View Post
    Feb 2013
    Ontario
    4,696
    2116
    2211
    I bet you could just put a suction cup on it and pull.
    991.2 GT3, Guards Red, Satin Platinum Wheels, Manual
    BGTS, Guards Red, Black/Luxor Interior, Satin Platinum Wheels (SOLD)
    Feb 2009
    New York
    942
    658
    223
    Quote Originally Posted by Wild Weasel View Post
    BINGO! Very good...I did just this and it worked like a charm...hope to have pics for all to see...this looked hard as can be - BUT it is really easy - you need to take care of not scratching the body, etc.
    Thomas
    2013 Boxster
    Feb 2013
    Ontario
    4,696
    2116
    2211
    Yay! Now I feel clever. _
    Feb 2014
    259
    64
    35
    For mine, all I did was loosen the screw in the trunk almost all the way, then give a good push with the screwdriver on the screw. Super-easy. No wheel removal.
    2013 Boxster S Aqua Blue Metallic Black/Carrera Red interior, PDK, Sport Chrono, PSE, PSS, 20" Carrera S wheels, Premium Pkg w/ 14 way seats, Infotainment w/ BOSE, UR-Windschott glass rear windscreen, stainless sills, painted roll-bars, GTS Rear Diffuser, SportDesign steering wheel, black taillights, debadged, 7/15mm Spacers (F/R), Xpel Ultimate full car, Crystalline tint @70%, Clearplex windscreen film
    Feb 2009
    New York
    942
    658
    223
    Hey...here is part of another thread here on tinted lights...see # 107
    https://www.planet-9.com/981-cayman-b...ights-yet.html
    Thomas
    2013 Boxster
    Dec 2014
    Omaha
    67
    Great write up. A note for 981 Cayman owners is that you first need to remove the small trim panels (they unsnap) from each side of the trunk in order to see the rubber plugs mentioned. After that it's the same process as described.
    Bitsobrits
    2015 Base Cayman 6spd-Agate Grey/Black-Sport Plus seats-PASM, PSE, PDLS
    Also in the garage: '63 Lotus Elan, '65 Jag E type FHC
    Feb 2016
    california
    64
    i used zip ties
    BC
    4,827
    1066
    1181
    We did this today on a Boxster, once the retaiing bolt was out a screw driver through the plug in the rear wheel well and out came the light... just like the manual said!
    2013 Boxster 981-S
    2006 Boxster Base
    Mar 2013
    SF Bay Area
    146
    148
    89
    Is it possible to re-link or use a different hosting service for the images or is there a PDF of the original installation instructions with the pictures?
    Thanks so much
    -Sam
    Quote Originally Posted by e00008 View Post
    Bruce
    2013 981 Boxster S |Platinum Silver/Agate Gray+18w Seats|Manual + PASM + PSE + 20" Carrera Classics + whole bunch more goodies...
    [Gone but not forgotten] - 2000 986 Boxster |Ocean Metallic Blue/Black P69 sport design interior|Manual + PSM + 18" wheels
    BC
    4,827
    1066
    1181
    Quote Originally Posted by cybersam View Post
    Thanks so much
    -Sam
    Sam, here is a link to another thread with additional information, this link will take you to my post with how it is done by Porsche techs, hope this helps.
    Al
    https://www.planet-9.com/981-diy-dis...ml#post1198193
    2013 Boxster 981-S
    2006 Boxster Base
  19. Remove Advertisements
  1. Removing tail lights smoke/tint
    By tenmad899 in forum Porsche Care and Detailing
    Last Post: 05-01-2013, 07:12 AM
  2. Brighter Reverse Tail Lights?
    By Stevie in forum 987 Cayman and Boxster Service and Tech
    Last Post: 01-05-2007, 09:46 AM
  3. Removing tail lights
    By Jayman in forum 987 Cayman and Boxster Chat
    Last Post: 12-27-2006, 09:41 PM
  4. Cayman led tail lights
    By andreigh in forum 987 Cayman and Boxster Modifications
    Last Post: 12-21-2006, 12:47 PM
  5. Tail light down!
    By Cayman Jason in forum 987 Cayman and Boxster Chat
    Last Post: 10-30-2006, 08:30 AM
