Effects of Aero Adjustment
Results 1 to 17 of 17
Thread: Effects of Aero Adjustment
    Jul 2011
    Athens, Ga
    543
    263
    109
    I can't find a thread on this that still seems to be active, so here goes. I posted my fastest lap at Road Atlanta in my new (2k miles) GT 4. Factory Aero settings. My top speed on the lap was 140, average speed 90.1. Like many others, though, I was hell bent on adjusting the Aero, and did so per the manual. This weekend, I posted a lap within a 10th of a second of the first one, but my top speed was only 131.6 while my average speed was 97.7. In fact, pedal to the metal numerous times the best I could get was 134 on that long back stretch. I also noticed high-speed passing seemed a bit more difficult. Does that seem consistent with your experiences with the supposed drag effect of the Aero? I had already vowed to be more aggressive in the corners, but I assume the Aero adjustment helped me some in that respect. Interestingly, the distance traveled in the more recent lap was .2 miles longer, suggesting that I was faster through the corners, but not as sharp. I realize there are other possible factors at play. I still don't have a clue about tire pressures on my !!$$!!&! Dunlop Sport Maxx Racers, and was fiddling with that all weekend. If I am missing something, please don't hesitate to ridicule me in pointing it out. Thanks for any and all feedback.
    Nov 2008
    Houston
    1,030
    203
    Re: Effects of Aero Adjustment
    What were the ambient temps for each day? In my experience with several cars and several different tracks vmax correlates strongly with temp. (cooler temps = more hp). I did the aero adjustment last time out at COTA but to be honest I couldn't feel any difference and too many other factors to isolate the aero effect if any. I ran 20in RE-71R for the first time. Great tire btw. Previously ran MPSC2. I did get a new best lap, but mainly due to having a rabbit and almost no traffic in the last session.
    2008 911 Carrera S (sold)
    2009 Cayman 2.9 (sold)
    2012 Cayman R
    2004 Boxster S
    2015 GT3
    Dec 2016
    814
    467
    210
    Well I'm no expert but simple minded explanation might be that your adjustment to the Aero increased you downforce, which helped corner speeds, but also increased your drag which lowered you top speed. As I said "simple minded explanation" but it makes sense to me. Good luck!
    Jul 2011
    Athens, Ga
    543
    263
    109
    Quote Originally Posted by RickH View Post
    Well, it must be "simple-minded" for sure, because that's my best explanation as well. Thanks!
    Jul 2011
    Athens, Ga
    543
    263
    109
    Quote Originally Posted by zedcat View Post
    This is quite possibly a factor, and my pilot friend suggested the same. The ambient temp was about 25 degrees higher this weekend. The thing is though, I have run much higher speeds than this weekend in a CGTS in much higher temps on the same track. I have to think drag from the Aero is also in play. I keep hearing great things about the RE-71R's. I am thinking about a set of those before my next track outing. Thanks for weighing in.
    Dec 2006
    San Francisco
    1,477
    423
    420
    Quote Originally Posted by cobby View Post
    What was the factory angle of attack and the post adjusted angle of attack? There is a $20 digital angle level tool on Amazon if unsure.
    I'm guessing 7 degrees stock and 12.5 adjusted? In theory that would change downforce from like 200 pounds to 300 pounds at 135 MPH.
    PA
    864
    105
    I have run max aero since I started tracking my GT4. I don't have the exact angle but believe it added about 4 degrees. There is no way that this can change your top speed and average speed by the amounts stated. When I went from the factory spoiler on my 987S to a Getty Wing my top speed dropped about 3 mph and lap times improved by about .5 seconds. Top speed is highly dependent on when you brake at the end of the straight.
    Jul 2011
    Athens, Ga
    543
    263
    109
    Quote Originally Posted by BillL223 View Post
    This was my gut feeling as well, although the adjustment clearly facilitated aggressive braking and I definitely took advantage of that. As I said, the tires could have been a factor--or maybe it was just the driver. Thanks.
    Jul 2011
    Athens, Ga
    543
    263
    109
    Quote Originally Posted by westwest888 View Post
    Thanks for the response. I keep hearing 2-3 degrees change only, but you could be correct.
    Dec 2006
    San Francisco
    1,477
    423
    420
    I was close. The media quoted number was 220 pounds of downforce. I'd guess that's at 250 km/h, or 155 MPH. Rear wings don't start working until 90 MPH, and don't really produce meaningful results until 130 MPH.
    At my tracks out in California, the front straight speeds don't really get over 130 MPH (140 in a GT3).
    Jul 2011
    Athens, Ga
    543
    263
    109
    I appreciate your checking that out and the additional info as well. I simply haven't measured the angle. Don't think the max angle is quite as steep as 12 degrees
    Dec 2006
    San Francisco
    1,477
    423
    420
    Someone smarter than me could figure out the stall angle - I'd hazard a guess at 15 degrees. The way Porsche sets it up is for low drag, for fuel economy. I like the kits that raise the height on the wing by 4". Those would provide cleaner air to the foil.
    Jul 2011
    Athens, Ga
    543
    263
    109
    Well, I know I need to learn more about this and I will. Thanks for your help. If there is reason to think that the settings did not hold down my top speed that much, there is reason to think they helped me through the corners. Car felt planted as heck in the faster ones.
    Dec 2006
    San Francisco
    1,477
    423
    420
    I did a bunch of the arithmetic to get my 59% nose heavy track Audi to behave more like a balanced car at speed. It took 4 seconds off at Thunderhill, more than any other mod I'd done including horsepower. Wouldn't have believed it unless I tried it. The downside is the car is -7 MPG. So I get like 19 going to the track instead of 26. But man can I get on the throttle early.
    Effects of Aero Adjustment-_dsc9271-jpg
    Jan 2015
    North Carolina
    470
    180
    102
    Gamertag: videodudes03
    Read some posts on rennlist from one of the Clubsport race series drivers and he said max aero makes 3-4 mph diff on long straight at Daytona. I've had mine on max for quite a while...
    2016 GT4, Guards Red, sport chrono, leather, CDR+, red stitch and belts
    2015 Fiat 500 Abarth, Red, 17-inch wheels-platinum, 6-sp auto, beats audio, sunroof, red leather
    2014 Cayman S, Guards Red, 20" wheels-platinum satin, sport chrono, leather heat/vent, 6 spd MT, red seat-belts (traded)
    Jul 2011
    Athens, Ga
    543
    263
    109
    Quote Originally Posted by Grand-Cayman View Post
    Thanks. I know the adjustment probably slowed me some on the straights, but for now, the cornering and braking advantages outweigh that. Over the winter though, I expect to go back to the factory setting.
    Jul 2011
    Athens, Ga
    543
    263
    109
    Tell me about the MPG. I am sure mine is off at least that much, if not more.
  20. Remove Advertisements
  1. Effects Of A Lightweight Flywheel
    By Herman in forum 987 Cayman and Boxster Modifications
    Last Post: 02-25-2015, 03:20 PM
  2. Add-ons! Effect of the high price on Cayman?
    By Coupé in forum 987 Cayman and Boxster Modifications
    Last Post: 07-04-2008, 06:00 PM
  3. Effects of S.Calif fires on Port of San Diego?
    By HMB-Croc in forum 987 Cayman and Boxster Chat
    Last Post: 10-31-2007, 01:24 AM
  4. Exact Effect of Sport Chrono
    By caySman in forum 987 Cayman and Boxster Service and Tech
    Last Post: 04-06-2007, 07:33 PM
  5. Positive effects of de-snork?
    By Nthusiast in forum 987 Cayman and Boxster Modifications
    Last Post: 07-17-2006, 12:04 PM
