Most Worthless 981 Option/Feature - Page 8
Page 8 of 8 FirstFirst ... 678
Results 141 to 158 of 158
Thread: Most Worthless 981 Option/Feature
  1. #141
    Dec 2014
    Michigan
    Re: Most Worthless 981 Option/Feature
    Quote Originally Posted by Stick_Figure View Post
    I wish I had the PS+, or at least I would like to try it. Turning the wheel full lock at slow speeds is difficult, to me it almost feels unassisted. The Ackerman bucking and jumping just adds to the fun. I assume it's so heavy to give it good weighting at higher speeds. Since this is really just a software change, it seems that it should be standard, with a menu option for people to just disable it if they don't like it. Ditto for rev matching.
    The upshift light is certainly unnecessary, although I've always assumed this is there to placate some environmental group somewhere.
    The upshift indicator is an artifact of the EPA emissions certification process rules and first surfaced long, long ago while I was a Big3 emissions/powertrain planner. At the time, for certification a car was driven on chassis dyno rolls over a specific fixed cycle of speeds and distances while the exhaust is collected for subsequent testing. The EPA driver was required to follow the upshift indicator as he operated the vehicle and tracked required speed and distance (following a line on an external TV screen). Doing so gave the OEM more control over engine speed and throttle use, usually resulting in better, more consistent test results. That a vehicle owner likely would seldom (if ever) follow the upshift indicator was recognized, but in many cases there was a tangible emissions certification benefit for the OEM so the upshift light became part of the emissions related content for specific vehicles.
  3. #142
    Apr 2016
    VA
    310
    254
    45
    Quote Originally Posted by Dracarys View Post
    Yeah, it's not a misalignment that's causing the overspray. Every car I've had that has headlamp sprays (2 BMWs, 1 Porsche) suffers this issue. Granted, if it is raining, you may not notice it. Or if it's winter and your car is dirty anyway, you may not care. But the spray will cover a decent portion of the front of the car and if your car is clean and dry, that may piss you off (at least it does to me).
    Why are your wipers running when your car is clean and dry?
  4. #143
    Oct 2016
    texas
    301
    83
    Quote Originally Posted by NetMage View Post
    Most Worthless 981 Option/Feature-becauseracecar-jpg
    981CS
  6. #144
    Dec 2014
    Alberta
    200
    444
    69
    Quote Originally Posted by hayden View Post
    Oooh excellent addition to the list. Upshift indicators are worse than worthless, they're downright annoying.
    Agreed, but having said that there is a way to disable it. I just don't know how. Reason I know this, is when I purchased my car there was no upshift indicator. 2 years later when I brought my car in for some minor auto body repair the upshift indicator suddenly appeared. Now I can't get rid of it...
  7. #145
    May 2013
    Northeast
    304
    375
    109
    That's a valid question. It's true that usually the wipers would not be running in such a case. The couple of times this happened, once I activated them manually just to see what would happen (regretted doing that), and the other time the windshield got dirty with some goop or something, so I was trying to clean it off (while driving) with wipers and fluid. I agree that it's not something that occurs often. But both those times, I had washed the car earlier that day.
    2015 Cayman S | GT Silver | Garnet Red Full, Natural Leather | PASM | PTV | PSE | PCM | Bose | Manual | 19" Boxster Wheels | Model Delete | White Dials | 14-way Seats w/ Ventilation | MF Steering Wheel | Smoking Package
    2002 M3 | Laguna Seca Blue | Black Leather | Ground Control suspension | Eisenmann exhaust
    (sold) 1998 M3 | Black on Black | Turner GroupN suspension | lots of go-fast parts
  8. #146
    Jan 2016
    Washington state
    17
    The speedo- maybe cut it in half and put oil temp on half and REAL water temp on the other half..
  9. #147
    Apr 2014
    MD
    1,046
    155
    255
    Quote Originally Posted by Fentanyl View Post
    Maybe they should have made it reconfigurable to a DOWNSHIFT indicator.
    The Land of No-Roof cars!
    2015 Base Boxster, Guards Red/beige, sport suspension/seats/steering wheel
    2007 Honda S2000, New Formula Red
    1964 Sunbeam Tiger, White with Guards Red stripes.
  10. #148
    Jan 2013
    Massachusetts
    341
    80
    Unless you are on the highway, if the indicator is NOT illuminated you should down shift; probably two gears.
    williamr
  11. #149
    May 2014
    796
    225
    245
    Gamertag: radonculousmd
    bar none the vanity mirror lights...VERY poorly placed in the that there are very bright LED lights on on either side of the mirror so that it blinds anyone that attempts to look in the mirror and if someone is able to look the reflection still remains very dark and essentially unusable...EXCEPTIONALLY poor...
    964 RS America
    981 Boxster S
    981 GT4
  12. #150
    Oct 2016
    texas
    301
    83
    Maybe launch control is the most worthless feature. Did anyone see the Grand Tour clip recently about it? Hilarious.
    981CS
  13. #151
    Mar 2014
    851
    17
    178
    That's really unlike Clarkson/May/Hammond, making a point which is reasonable and helpful. I agree with them and have made most of the same points myself.
    2015 Cayman S, Sapphire Blue.
  14. #152
    Apr 2012
    USA
    1,136
    555
    I didn't even realize there was a passenger side net. I'll have to start shopping for something to put in there...
    I stick a small thick plastic bag in there. Passenger barf bag. Shouldn't ever have to use it, but that $0 cost option can potentially save a ton of money one day.
    I think an overlooked option if you already have deviated stitching is "steering column covered in leather". When you look forward it's basically the only real plastic you notice. Makes a difference.
    For useless options though... definitely a few aesthetic things I had done one-off at special request by Porsche Exclusive. These were basically parts you can't tick a box for in certain configurations, but damned if people haven't noticed them (and ask how I had it done). Though lordy do they charge you for that privilege -- about triple the cost of the part at the parts counter. Only worth it on a dead man's car, and for things that can't easily be done (or are very labor/skill intensive) after the build.
    Forever: 2016 Boxster Spyder
    Past: 2015 Cayman GTS, PDK, X73 SS, PTV
  15. #153
    Jan 2015
    North Carolina
    470
    180
    102
    Gamertag: videodudes03
    Au contraire, my red seat belts and dials make my car at least twice as fast.
    And according to NC State Trooper Thomas, the red paint, dials, and seatbelts contribute to a "red-shift" of sorts of the car's radaricon signature making it appear faster to him too!
    2016 GT4, Guards Red, sport chrono, leather, CDR+, red stitch and belts
    2015 Fiat 500 Abarth, Red, 17-inch wheels-platinum, 6-sp auto, beats audio, sunroof, red leather
    2014 Cayman S, Guards Red, 20" wheels-platinum satin, sport chrono, leather heat/vent, 6 spd MT, red seat-belts (traded)
  16. #154
    Oct 2016
    texas
    301
    83
    Quote Originally Posted by Grand-Cayman View Post
    I think you probably have my ideal spec 981, tbh. Red on black GT4 with red accents and the satin wheels...drool. I have black/black with red accents for sort of the same color scheme, but no GT4
    JEALOUS!
    981CS
  17. #155
    Jan 2015
    North Carolina
    470
    180
    102
    ... but no GT4 JEALOUS!
    I've driven the CS and GT4 back to back and driven with 3.4 CSs at the track (used to have a '14 CS too). I love the GT4 and the 3.8 L engine, big brakes, wing, etc. but the performance differences between the GT4 and CS and GTS are not all that huge.
  18. #156
    Oct 2016
    texas
    301
    83
    Sure, but the styling of the GT4 is just too perfect. The hood "gap" especially -- not sure what you GT4 folks call that black strip in front of the hood but above the front bumper.
    981CS
  19. #157
    Jan 2015
    North Carolina
    470
    180
    102
    I think what you are talking about is the air exhaust for the center radiator. Agree, that is cool - the GT3s have it. I saw a thread on the possible GT4 RS - after you get that you can tell me about all of its cool features!
  20. #158
    El Paso, TX
    2,427
    I don't like that at all, plus it makes for an even bigger overhang. Go figure. Ha ha. I was offered a GT4 at MSRP, meaning a lower price than my fully-optioned GTS... and opted for the GTS. Go figure. Ha ha. My main detraction from those cars is the lack of any luxury amenities, that for some bizarre reason Porsche doesn't offer (McLarens, Ferraris, etc. all offer luxury options like parking sensors, memory, nice stereo, etc). They like to make a killing on options, so not offering seems stupid to me. And since I like my sports cars also luxurious, GT cars don't appeal to me. Plus the GT4 is not a true GT car since it has a detuned Carrera S engine, not a motorsports engine, like GT3s. But it's the best performing manual Cayman you can buy for sure. I also got tired of the engine screaming on the highway in 6th, so since Porsche didn't drop the 7-sp on Caymans, opted for PDK this time. Couldn't be happier, even though I'm a manual guy at heart. I didn't want a manual just for the sake of having a manual anymore.
  21. Remove Advertisements
  1. Speedhunters - 981 Boxster Feature
    By jwwu in forum 981 Chat
    Last Post: 03-06-2013, 10:07 PM
  2. 981 Boxster feature coding
    By mikeinalexandria in forum 981 Chat
    Last Post: 12-03-2012, 02:38 PM
  3. Replies: 0
    Last Post: 04-01-2010, 02:00 AM
  4. Replies: 0
    Last Post: 03-31-2010, 08:10 PM
  5. Most important Cayman S features...
    By Faresco 87 in forum 987 Cayman and Boxster Chat
    Last Post: 07-14-2006, 09:08 PM
