Air conditioning weirdness
Results 1 to 5 of 5
Thread: Air conditioning weirdness
    Feb 2017
    South Carolina
    574
    372
    198
    On my way back from dentist (implants, waiting for pain med to kick in) and my a/c was blowing warm air. Turn it to max a/c and it blew cold. Back to normal and blows warm.
    While waiting at drugstore to drop off prescriptions at drive-through I turned the fan all the way up in normal a/c mode and it blew cold thereafter.
    I will get it checked later this month, but wondering if any of you experienced anything like this? Warm day today but it has been working fine the past 2 years in hotter weather.
    '14 981 Base - Agate Gray Metallic / Black leather, PDK, PS+, Sports Chrono Pkg (i.c.m. PCM), 19" Cayman S wheels, MF steering wheel, heated seats/steering wheel, 14 way seats w/ memory, Bi-Xenon w/ PDLS, Infotainment pkg, 2 Zone Climate, Dimming mirrors
    Previous: 1992 Toyota MR2 / 1984 Nissan 300Z / 1978 BMW R100RS / 1972 Suzuki GT380
    Jul 2018
    Oregon
    120
    80
    35
    Re: Air conditioning weirdness
    Both of the AC lines that connect to the evaporator failed on my 2014 CS. They were bad when I bought the car at 24k miles. They leaked compressor oil all over the gas tank and onto the headlight leveling sensor in the passenger side wheel well.
    Look under the car in the passenger wheel well for that sensor/plug, mine was soaking wet and shiny, covered in dirt that was stuck in the oil. If you're having those problems, it'd be obvious if that's the cause.
    Feb 2017
    South Carolina
    574
    372
    198
    Thanks! Will check it out shortly. My car is right at 25k miles.
    Jul 2018
    Oregon
    120
    80
    35
    The lines connect to the evaporator behind/under the battery. You should be able to inspect them a bit with a flashlight without moving it if you just pull the cover off in the frunk.
    Feb 2017
    South Carolina
    574
    372
    198
    I checked all I could see and nothing seemed amiss. Went for a drive and no issues. Beginning to wonder if I had turned off the a/c when I left the dentist office in a less than happy state. Getting an oil change in a couple of weeks so will have them check the system then if it returns.
    Thanks for the help!
  8. Remove Advertisements
  1. Has Air Conditioning cooling been an issue yet?
    By jsdone in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 09-19-2014, 04:13 PM
  2. Air Conditioning in 107F weather
    By hsjb in forum 987 Cayman and Boxster Chat
    Last Post: 07-23-2011, 09:07 AM
  3. Rides That Rock - Air Conditioning Conversions
    By K-Man S in forum Rides that Rock Podcasts
    Last Post: 07-06-2009, 02:18 PM
  4. Air Conditioning Eruption
    By BullShark in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 06-22-2008, 01:17 PM
  5. Funny Smell in Air Conditioning
    By tforgan in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 08-22-2007, 12:51 AM
