Bought a Philips HID kit but instead of putting in a 4300k or 6000k H7 bulb, I installed a JDM 5000k bulb. I like that there is no hint of yellow or blue, just pure white that matches the daytime LED driving lights.
NOTICE - Before adding photos to posts on Planet-9, please review: Posting Photos on Planet-9
I had the same problem with the two pronounced shadows on each beam due to the wire. How did you notch it? I think that was the problem and returned the kit. Does the light have any issues with stability? If you have photos of where you notched it that would be great!OK, my update. The kit works fine. However, the light bowl in the 981 places HID ground wire on top. Easiest fix is to notch the H7 bulb base to allow it mounted 180 degrees (ground wire at 6, not 12). If Cosmo didn't do this, he will have two pronounced shadows in each beam. Properly mounted, the xenons give same pattern, same cut-off and are very *BRIGHT*. Liking the difference I used 5000K bulbs. Nice color, not ricey...
