Headlight Cracks
Results 1 to 12 of 12
Thread: Headlight Cracks
    Sep 2015
    Arizona
    Headlight Cracks
    Both my headlights suffer from severe micro cracks, they look terrible. I took them to the dealer and they said "sorry we've never seen anything like this before" and "what did you do to them" Short of buying new/used ones as the only option, does anyone make replacement lenses yet?
    Fire
    Sep 2015
    Atlanta GA
    981
    77
    280
    Re: Headlight Cracks
    This is a well known issue with the 981. What you are seeing is the cracking of the factory clear protective film over the lense. There are several threads and complaints about the issues over the various Porsche forums but no conclusive reason as to why some peoples cars are doing this and others not. Those under warranty have had them replaced, however its very expensive outside of warranty at about $1,500+ per light.
    There was one recent thread from someone who used fine grit sandpaper to remove the cracked film and then gradually polished the lenses back to normal again.
    Sep 2015
    Arizona
    I wish it was just the clearcoat, it's the actual lense that has the micro cracks. I had them refinished and the cracks are still as awful as ever.
    Aug 2016
    fl
    725
    119
    I could have sworn that this was a warranty issue.
    BC
    4,914
    1088
    1220
    Even with pictures (didn't see any...) it would be hard to tell without seeing them in person.
    As for sanding or polishing. be aware most if not all light housings are coated, this coating protects the plastic, remove it and the plastic begins to deteriorate... IMHO this is a temporary fix.
    If the housing plastic is cracked then replacement would be the best option.
    2013 Boxster 981-S
    2006 Boxster Base
    Mar 2017
    Arizona
    35
    Hi firecapt,
    I posted my solution on Rennlist here: https://rennlist.com/forums/porsche-...scratches.html
    While not for the faint of heart, my solution worked fine and I would recommend it. I actually wish I had spent a little more time on the passenger side, but I did it first for a reason. I don't see it every time I get in the car.
    Not in the post is further learning that the scratch/crack problem has to do with HID's run long in the rain. When I picked up my '14 CS in Atlanta the lights were just fine. I drove 2000 miles to Phoenix often in the rain in the dark. Some stints where 13 hours with only fluid in/out breaks for the Cayman and me. (Did I mention I love my Cayman?) The cracking showed up about 6 months later. The HID lights were/are awesome, and I have the PDLS as well. Replacement "shells" run $1800 at Suncoasticon. My solution was under $300 but took about 10 hours of my time. PM me if you want more details.
    '14 Cayman S, MT, SE, Serious Fun
    Aug 2012
    NV
    103
    17
    I have had mine replaced twice under warranty on my 2014. It only gets delaminated on the black coloring around the edges. My car is only driven 3 days out of the week to a coverer parking spot.
    Mar 2017
    Arizona
    35
    Good for your snoopy. My local dealer wouldn't cover them blaming Porsche corporate. Local AZPCA sponsor wanted $500 to fix. I guess I should have let them as my 10 hours and $300 exceeded that. I do have the satisfaction of a DIY FWIY.
    Jun 2016
    Oregon
    318
    44
    My dealer is asking $889 to replace them even though I brought it up when the warranty was about to expire. I didn't know about the issue before that. Should I replace them?
    Feb 2014
    447
    79
    If you're experiencing the delamination, new ones are going to do the same thing.
    Jun 2016
    Oregon
    318
    44
    what do you recommend? What is the cause? Anyone knows?
    Aug 2016
    fl
    725
    119
    Quote Originally Posted by takeshi View Post
    It’s possible, but not guaranteed. Mine don’t have this issue, so that is proof that not all of these have the issue. I’d expect that Porsche would have addressed this issue by now considering the cost.
    Anyways, if I did have the issue, I’d have them replaced no matter what the chances are of having a repeat.
  15. Remove Advertisements
  1. Bi-Xenon vs. Halogens headlights
    By VicL in forum 987 Cayman and Boxster Chat
    Last Post: 08-19-2009, 06:18 AM
  2. Do headlights turn off automatically?
    By Fiebru in forum 987 Cayman and Boxster Electronics
    Last Post: 05-29-2006, 10:41 PM
  3. Bi-Xenon headlights? I think NOT.
    By BiggerTwin in forum 987 Cayman and Boxster Electronics
    Last Post: 04-15-2006, 02:40 PM
  4. 91 Fwy Sucks - Cracked Windshield
    By Carbon Cayman in forum 987 Cayman and Boxster Chat
    Last Post: 03-28-2006, 06:08 AM
  5. Stolen Headlights
    By ExecDrew in forum 987 Cayman and Boxster Chat
    Last Post: 02-16-2006, 07:17 AM
