painting lug nuts
Results 1 to 8 of 8
Thread: painting lug nuts
    Jun 2016
    Oregon
    306
    43
    painting lug nuts
    Getting ready to paint the calipers (in-place). While I'm at it, taking care of cleaning up the wheels, wheel wells, rust around the rotors and lug nuts etc. The nuts now look very good after
    soaking in Evopo-Rust overnight but the paint on them is not in good condition. So, thinking of painting them. In old threads on this topic, I saw some comments about paint chipping off
    after awhile. Anyone has good paint recommendation? Just go with VHT wheel paint/primer?
    Also, started the preparation few days ago and the car has been on jack stands and looks like I'm going to take few more days to complete this. OK to leave the car on jack stands for
    extended time?
    1,538
    102
    255
    Re: painting lug nuts
    Painting success/durability is all about the surface preparation. Skimp on that process, and you'll get whatever results you've earned.
    A few days with the car perched on jack stands won't hurt the car, but long-term storage in that state, with the suspension unloaded, is not recommended as I recall.
    Best regards,
    Croc'ed
    Sep 2017
    VT
    104
    I painted mine with Wurth European Blend Silver Wheel paint and they have held up well (1.5 years with multiple wheel removals). I put a stainless brush on a Dremel and cleaned the scale and surface rust off of them. I then prepped them with some rubbing alcohol, then sprayed them with Wurth self etching primer, the Wurth Sliver then the Wurth clear. I individually taped the threads and collar on each bolt so I ended up just spraying the heads. A pizza box with some holes drilled in it makes for an easy way to spray them all at once (and carry them around). Next time I will go buy some titanium boltsicon :-)
    Attached Thumbnails Attached Thumbnails painting lug nuts-20170831_145145-jpg   painting lug nuts-20170903_115546-jpg   painting lug nuts-20170903_105551-jpg
    2009 Boxster Base
    BC
    4,809
    1064
    1177
    Quote Originally Posted by zuch View Post
    They turned out great, but I went with the Titanium route...
    https://www.acerracing.com/collections/porsche
    Attached Thumbnails Attached Thumbnails painting lug nuts-acer-racing-titanium-lug-bolts-jpg   painting lug nuts-20170601_164700-jpg   painting lug nuts-20170601_164714-jpg
    2013 Boxster 981-S
    2006 Boxster Base
    Sep 2017
    VT
    104
    Yeah, those look great. Techie question....do you still use Optimoly lube with those? I assume you still need to use some kind of thread lube? Switching metal alloys always scares me, especially when you are connecting to a different alloy (obviously neither the wheel nor the hub are titanium) and I have never seen a statement on what thread lube to use with the titanium boltsicon. Lots of people use titanium and have good luck so this is primarily a curiosity question. I freaked myself out similarly with an ignition coil bolt. I stripped one of the original ones and replaced it with stainless but after a week I ordered the OEM version just because I was worried about the different alloys :-) I should have paid more attention in my materials classes in college.
    2009 Boxster Base
    BC
    4,809
    1064
    1177
    According to my reading (Porsche owners manual), no lubrication should be used, and as always clean wheel bolts before fitting. It is my understanding that lubrication will alter the torque values and of course Porsche does not recommend nor endorse anything but genuine Porsche wheel bolts.
    I have been running Titanium bolts installed clean and dry, torqued to 118ft/lbs on the wheels pictured above for nearly 4 years now, no evidence of dissimilar metal interaction or corrosion has been noted. This has been my experience, but as usual YMMV.
    2013 Boxster 981-S
    2006 Boxster Base
    Sep 2017
    VT
    104
    Interesting. My 2009 owners manual calls for lube and a lower torque value of 96 ft-lbs (shhhh, don't tell anybody I'm in the 981 section).
    2009 Boxster Base
    BC
    4,809
    1064
    1177
    No worries, you're among friends, and contrary to popular belief we even like 718's!
    Yes, on previous Boxsters that I have had (2003,2006), the wheels bolts were silver and the torque spec as you mentioned was 96 ft/lbs, the 981's have black bolts which spec out to a higher torque, curious why the change in lubrication...
    2013 Boxster 981-S
    2006 Boxster Base
  11. Remove Advertisements
  1. Lug Bolts vs Lug Nuts
    By Coloradocurt in forum Porsche Tires & Wheels
    Last Post: 05-21-2019, 05:15 PM
  2. Powder coating lug nuts?
    By oregonduckman in forum 987 Cayman and Boxster Modifications
    Last Post: 05-17-2010, 07:58 PM
  3. Chrome Lug Nuts on the Cheap
    By iremembercliford in forum Porsche Tires & Wheels
    Last Post: 01-13-2009, 07:12 PM
  4. Anyone know where to find black open end lug nuts?
    By dustindb in forum 987 Cayman and Boxster Modifications
    Last Post: 04-23-2008, 12:40 PM
  5. where can i find open ended lug nuts for the CS?
    By fafnir in forum 987 Cayman and Boxster Chat
    Last Post: 01-12-2007, 07:41 PM
