Cayman Race Car Build - Page 12
Page 12 of 12 FirstFirst ... 2101112
Results 221 to 238 of 238
Thread: Cayman Race Car Build
  1. #221
    Mar 2008
    1,316
    40
    124
    Re: Cayman Race Car Build
    Quote Originally Posted by diverdog View Post
    Motec does have traction control and with 700HP I hope we can get it to work!
    Putting down 700HP with what tires/size?
  3. #222
    Mar 2008
    NV
    2,553
    85
    332
    330/710R/18 Yoko slicks
    2007 4.0L Twin Turbo Cayman S Race Car
    2013 Boxter S PDK Daily Driver
  4. #223
    Mar 2008
    1,316
    40
    124
    Mid-mounted 700HP and 13" slicks? Oh my, that sounds like fun.
  6. #224
    Mar 2008
    NV
    2,553
    85
    332
    Wanting to upgrade the Porsche tranny to this sent me down the rabbit hole. Can't wait to feel how it shifts!
    Attached Thumbnails Attached Thumbnails Cayman Race Car Build-shift-cylinder-jpeg
  7. #225
    Dec 2011
    Nj
    211
    In for feedback.
  8. #226
    Mar 2008
    NV
    2,553
    85
    332
    Well after an eternity and a half the beast started today. Unfortunately the turbo oil scavenging didn't work properly and it had to be shut down before any tuning could be done but I'll take it. Integration of the engine, transmission, suspension, ABS and data gathering is almost done. CFD aero analysis has pointed the way to an efficient package that produces meaningful DF with a good center of pressure and minimal drag. It was fun applying lessons learned and I can't wait to drive the car and feel the results on the very high speed turns at Willow Springs
  9. #227
    Oct 2015
    OREGON
    276
    118
    46
    Awesome, congrats!
  10. #228
    Mar 2008
    NV
    2,553
    85
    332
    Spent all day yesterday on the dyno looking for the throttle surge issue. Sticky waste gate and adjusting the cam transition set point fixed the issue but it was damn hard to diagnose. New fuel system worked perfectly. I never think of Porsche engines as torquey but this one is a torque monster. 635 lb/ft at the wheels! Moved our test day from Friday till next Thursday. Temps expected to be 65. Much better than Fridays high of 50. Infinite torque and no traction sounds like a bad idea!
  11. #229
    Mar 2008
    NV
    2,553
    85
    332
    Finally a test day at WSI last Thursday. All of the throttle issues that plagued the first test have been resolved. Boy did it feel strange to be driving a race car. Talk about sensory overload! Just the sounds alone are so different. The side exhaust, straight cut gear whine, turbo whistle, and blow off valve all sing a much different song! The super stiff chassis and cup car suspension communicate every bit the road feel. On low boost the engine almost feels normally asperated, no turbo lag and huge torque. Acceleration in 4-5-6 is unbelievable and to be truthful a bit scary! It always takes me some time to adjust to the limits of a race car and it will be a while before I'm dialed in.
    Unfortunately an overheated gearbox cut the session short. Not sure if it's a cooling pump issue or if it need a bigger HX. Hopefully it will be easy to fix as the next race is at Buttonwillow Fri-Sun
  12. #230
    Mar 2008
    NV
    2,553
    85
    332
    I'm beginning to think I was born under a bad sign! While qualifying at Buttonwillow a rock hit the engine pulley and popped off the water pump belt! I only ran two laps but the engine overheated badly. The good news is the bottom end of the engine is OK but I ruined some valve guides and exhaust valves. Never a cheap repair for any of this!
    Normally the entire bottom of the car is covered but we had the diffuser off to allow for easy inspection / adjustments.
    While the engine is out I had Vision mount oil drain fittings at the back of each head and the bottom of the IMSicon housing. As time permits we can add the 4 stage Dailey pump and Peterson oil tank without having to remove the engine to have a real 18 quart dry sump system
  13. #231
    1,538
    102
    255
    I'm curious...how do you know that a rock dislodged the belt? What evidence supports this conclusion? I'm not trying to be antagonistic, but if I were you I wouldn't want this to happen again so I'd want to be sure of the cause before declaring it an anomaly.
    Best regards,
    Croc'ed
  14. #232
    Mar 2008
    NV
    2,553
    85
    332
    The dent on the pulley is the key indicator. Also this is the same engine and pulley drive that was fine for many street and race miles. Needless to say if I get another high engine temp alarm I'm going to shut it down immediately!
  15. #233
    1,538
    102
    255
    Wow, sorry to hear it. Tthat's some really bad luck. High engine temperatures can have serious consequences, as you've discovered. Best of luck going forward.
    Best regards,
    Croc'ed
  16. #234
    Mar 2008
    NV
    2,553
    85
    332
    I'm really excited that the car will be ready to go for next weekends POC race. Engine location fixed, new turbos, cool air for gearbox HX and a better intercooler scoop.
    I love this pic shot by Martina Kwan at WSI. Some may call it dirt but I call it track patina!
    Attached Thumbnails Attached Thumbnails Cayman Race Car Build-wsi-5-1-19-crop-jpg
  17. #235
    Mar 2008
    1,316
    40
    124
    Great shot.
  18. #236
    Mar 2008
    NV
    2,553
    85
    332
    Quote Originally Posted by Walter View Post
    Great shot.
    ? well we moved the engine to the back where a proper Porsche wants it! LOL A technician that no longer works at Vision installed the engine and gearbox in the car without 1" lowering spacers. The resulting axel angle caused CV joint issues. Vision stepped up and fixed it gratis. I'm very excited because lowering that much mass 1" will really improve the center of gravity!
  19. #237
    Mar 2019
    Yeah... I had an issue like that cost our team an engine rebuild in the Mint-400 one year. Driver of Record/Car owner dragged the engine through a bush, ripped off the belt and his co-driver didn't say anything about the big yellow light pointed at his face that isn't normally on. Unfortunately that was before my stint so I didn't get to drive that day .
  20. #238
    Mar 2008
    NV
    2,553
    85
    332
    Quote Originally Posted by M1Combat View Post
    That stinks! The diffuser is back on my car so hopefully the belt drive will be protected from foreign objects
  21. Remove Advertisements
  1. New Cayman race car build
    By mikew968 in forum 987 Cayman and Boxster Competition
    Last Post: 10-18-2015, 04:23 PM
  2. New 2010 Cayman S Race Car Build, How 'Bout Wheels?
    By CP Louie in forum 987 Cayman and Boxster Competition
    Last Post: 07-31-2014, 10:27 AM
  3. MLD Racing Cayman S Track/Race Car Build
    By mdavis in forum 987 Cayman and Boxster Modifications
    Last Post: 01-18-2013, 07:46 PM
  4. Cayman S Race Car Build
    Last Post: 01-03-2013, 05:32 PM
  5. Cayman Race Car Results!
    Last Post: 07-14-2011, 12:09 AM
