Side to side movement in strut normal?
Results 1 to 4 of 4
Thread: Side to side movement in strut normal?
    Sep 2015
    Ohio
    140
    I have an odd vibration coming from car. Full prepped 987 with JRZ RS Pro struts. When checking everything I noticed the the section of the rest struts where the rod enters the strut sleeve (at strut seal) wobbles a very small bit back and forth. When I grab wheel at 3&9 there is no movement but when I grab at 12&6 there is some very slight movement. Btw these tests were down with car under load (jack stand as far out on axle as possible) and there is no wobble when car in on lift unloaded. Is a small amount of movement normal? Appreciate all your help!
    Jan 2016
    Washington
    677
    125
    Re: Side to side movement in strut normal?
    Try the other side to see if that side wobbles as well. Depending on how lowed your car is, the shock rod should be close to the middle of its intended travel. Also, what does JRZ say about shock wobble? They are the experts on how their shock is put together.
    2007 SC, Bi Xenon, roof rack, red tail light kit, Ohlins R&T, Tarett Cup LCA's f&r, Tarett GT sway bars, down links, Elephant toe & bump steer links f&r, r toe locker plates, f slotted frame camber mount, Pedro's technolink brace, Function First orange motor mount insert, Numeric short shifter&cables, GT3 throttle body & Agency Power Plenum, EVOMS V-flow Intake, Milltek Muffler & tips, GT2 brake ducts f&r, Signature SV104 forged monoblock Black Chrome Powder coated 18 race wheels, RE71R's tires, LN deep 2 Qt sump & skid plate, Porsche Motor sports AOS.
    Sep 2015
    Ohio
    140
    Spoke to JRZ and they said “no wobble at all should be detected there.” Putting all new bearings in this week and will run this weekend. If vibration still there will have struts rebuilt (will probably do this anyway as they are due)
    Oct 2015
    OREGON
    276
    118
    46
    You should not have any play in the strut shaft. If you do the guide bushing is toast and they will need a refresh.
  7. Remove Advertisements
  1. Slight front end movement - should I worry?
    By Dinoeck in forum 987 Cayman and Boxster Chat
    Last Post: 03-21-2014, 04:10 PM
  2. "Green Car" movement: Cayman S color change
    By Dave_Car_Guy in forum 987 Cayman and Boxster Pictures & Video
    Last Post: 01-08-2014, 02:01 PM
  3. Boxster S 987.1 automatic Rev Movement
    By emrah136 in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 11-20-2013, 05:48 AM
  4. Liquid movement noise in engine bay - cold weather
    By craig in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 02-14-2012, 09:41 AM
  5. Question Shifter Movement
    By beleary in forum 987 Cayman and Boxster Chat
    Last Post: 10-08-2009, 12:07 PM
