Installing an aftermarket dbl Din Nav Head Unit and Amp in my 2005 Boxster (Bose sys)
Results 1 to 3 of 3
Thread: Installing an aftermarket dbl Din Nav Head Unit and Amp in my 2005 Boxster (Bose sys)
    Apr 2019
    I know there is alot of ppl just like me, have or are attempting to do a self install on thier Porsche. I know because like most i combed the web for weeks gathering info on many aspects of the audio replacement.
    I found alot of different and sometimes conflicting info. Honestly the hardest and most time consuming part of the entire project was getting all the info you need to even know what you can and cant do, just so you
    can order what you need to cut down on the trial and error you are certain to do be faced with. I am going to post a site that i found, that has all the information you will need in one place. Seriously I didnt have to leave
    the site to track down anything i had questions about from start to finish. I Installed a dbl din H.U. and 5-channel amp, leaving the factory bose speakers and wiring intact (minus the wiring harnesses i removed to hard wire
    my equipment.
    https://cai-store.com/pages/install-...es-for-997-987
    Yes i know alot of ppl already use this site and know about it. This post is not for them. I do this because my search engines did not put this site anywhere near the top of any searches i tried. And when
    you want the info asap without reading what amounts to the equivalent of "war and peace" in material. i hope it saves someone out there a little time and frustration.
    Mar 2019
    Re: Installing an aftermarket dbl Din Nav Head Unit and Amp in my 2005 Boxster (Bose
    Thanks dude
    Nov 2017
    Colorado
    That page was a big help. I even ordered the Sat antenna holder from them.
    2008 Boxster S
  1. Swapping CDR-31 head unit for PCM 3.1 head unit on 981 Cayman or Boxster
    By quest in forum 981 Cayman and Boxster Electronics
    Last Post: 05-21-2019, 07:26 AM
  2. PCM 2.1 (Head unit & DVD drive) with 05.2007 DVD & bose amp too!
    Last Post: 04-17-2011, 05:30 PM
  3. Single DIN or Double DIN head unit w/BOSE?
    By Hi_Fi_Guy in forum 987 Cayman and Boxster Electronics
    Last Post: 04-15-2010, 04:46 PM
  4. WTB aftermarket double din NAV unit
    Last Post: 04-14-2010, 12:30 PM
  5. Double Din aftermarket head unit
    By dangerfish in forum 987 Cayman and Boxster Electronics
    Last Post: 07-11-2006, 01:03 PM
