TPS battery replacement?
Results 1 to 15 of 15
Thread: TPS battery replacement?
    Oct 2018
    I have read that after a certain amount of years I will be getting the TPS warning because the batteries in the sensors are dead. Do I have to then replace the whole sensor or can I just replace the little battery in them?
    Mar 2014
    KY
    773
    1275
    292
    Re: TPS battery replacement?
    So I'm getting ready to replace all 4 tires on my 2014 CS. The TPS units are new and 5 years old. Should I replace them while the tires are getting replaced?
    BC
    5,020
    1108
    1258
    Quote Originally Posted by unzie57 View Post
    I am not aware of any TPMS sensors that are designed with replaceable batteries, considering how they are sealed, any replacement of the battery will likely compromise the sensor as well therefore not recommended.
    The batteries have projected lifespan of 5-8 years, considering the labour cost to remove and reinstall tires, replacing the sensors as a set is the best advice.
    2016 Boxster GTS
    2013 Boxster 981-S
    2006 Boxster Base
    Mar 2014
    KY
    773
    1275
    292
    Good deal....thanks. Any idea what I can expect to pay for those (at my Indy shop)
    BC
    5,020
    1108
    1258
    Quote Originally Posted by Rickyb View Post
    Considering the age of the sensors and the mounting cost of tires, personally I would replace the sensors at the time of tire installation, you could keep your fingers crossed that they continue to work, but you might be back to the tire shop and pulling the tires back off again if they start to act up or fail.
    2016 Boxster GTS
    2013 Boxster 981-S
    2006 Boxster Base
    BC
    5,020
    1108
    1258
    They vary in cost depending on brand, but I would budget around $70/ea for the OEM brand (Huf), although I have seen sets of less popular brands for 1/2 that.
    2016 Boxster GTS
    2013 Boxster 981-S
    2006 Boxster Base
    Aug 2013
    MD
    I know that RIckyb asked for cost at an indy shop, but I just so happen to have had my 981 serviced this week. They said I will be needing TPMS at some point and quoted me $220 for each sensor, $49.39 for each valve, and $272 for labor. Total for 4: $1,449.21. Not getting them there. By the way, do you need to replace the valves when you replace the sensors?
    2014 981 Boxster, White, Yachting Blue Lether Pkg, Roll Bar painted Wite, PDLS, Premium, Bose, 19" BS wheels, Sport Design SW, 14W seats, heat/vent, ACC, ParkAssist, LDP, folding mirrors
    Jan 2008
    Southern MD
    77
    Quote Originally Posted by Linthorn View Post
    oewheelsllc.com. I've bought several sets of TPMS sensors from them before and never had an issue. Last set for my other cayman was $165 for all 4... and the valves are part of the sensor, so it's disingenuous to charge for both IMO. Looking today, they are about $169 for OE Huf brand ones. Most tire shops charge around $20-$25 for mount/balance. While you should replace them when you do the tires just to make sure (which I forgot to do with my most recent tires...ugh), it should not cost anywhere near $1400 to do it after the fact; the prices you qouted are insane.
    Aug 2013
    MD
    Quote Originally Posted by av8bpilot View Post
    Sorry, thought I mentioned it but it was at the dealer, not an indy.
    Oct 2007
    Calif.
    920
    256
    67
    Go independent! Dealers wanted $1400 for all 4 out the door. My indy mech put all 4 in for $450!!! They have been running perfect for 4 years to date.
    Mar 2009
    2,170
    836
    620
    Agree with the oewheels suggestion. Bought my last set from them and they've worked at least as well as the originals and have lasted longer. Still going strong after about 7 years. An alternative would be TireRack.
    Jan 2010
    3,064
    54
    I'm still running my original sensors on my 2010 (~86000 miles). I'll wait until one dies before replacing since it isn't a show-stopper. I only preemptively replace things that would leave me stranded if they malfunction. TPMS would just be an annoyance. BTW, it isn't hard to replace your own if needed. Plenty of youtube vids.
    I figured I'd replace the set with my next tire change but that might be a while. By then they'll be 10 yrs old.
    BTW, Durametric will read the sensor battery condition and estimate its remaining life expectancy. Last time I checked (a couple yrs ago) it said greater than 1 yr.
    Jan 2015
    62
    the labor to install each sensor is $15-20 at a tire place (mount/balance), so you are looking at $60-80 savings if you replace them at the tire of tire swap. Some shops charge extra to replace the tpms in addition to the dismount/mounting/balance of tires, but my shop doesnt. So that depends how much longer your tpms can stay working...if they can last another 3 years i wouldnt replace them now. The tpms usually lasted 9 years in my experience (happened twice in past cars)
    2013 Boxster - pdk,k&n
    2012 R8 V10
    2011 458
    2015 GT3
    SOLD 07 IS350 03 G35 01 3.2CL 89 Supra
    Oct 2018
    Thanks everyone for the input. I looked on Amazon and they have a set of 4 by Mobiltron for $98.50. Good feedback posted but you never know. Anyone had experience with this brand?
    Jan 2019
    I live near Portlandia, Oregon and have a 2008 Cayman S. In January a local tire store put a set of ITM 433 mhz sensors on my car. These are generic units that are programmed for your car and sent to you ready to go. The cost for four from Amazon was $151.22, including tax. ANT Tire, also known as Trackside Motorsports, installed them for $80. I was in and out of there in 20 minutes and the sensors began working correctly within two miles of the shop. These are still working fine 6 months later.
  18. Remove Advertisements
