Cayman R Suspension Retrofit - New Top Mounts?
Results 1 to 13 of 13
Thread: Cayman R Suspension Retrofit - New Top Mounts?
    Jan 2018
    I found a lightly used set of Cayman R dampers, which will be replacing the stockers in my 2009 base Cayman. They didn't come with any top mounts. My stock top mounts have 60K miles on them. Should I plan to re-use them or should I just splash out with new ones at this mileage, considering everything will be apart? Obviously I can examine the condition of the existing top mounts when I remove them, but wondering what the consensus is... Thanks.
    Oct 2016
    Ontario
    255
    52
    Re: Cayman R Suspension Retrofit - New Top Mounts?
    I installed Cayman R (X73) suspension on my 2010 Cayman Base and reused existing mounts. The car had around 50K miles on it. No issues whatsoever.
    You may consider replacing LCAs if you care about camber adjust-ability. X73 also comes with thicker sway bars, so you may want to look into that as well.
    2010 Porsche Cayman, Midnight Blue, Toronto, Canada
    Mar 2008
    1,757
    732
    694
    Quote Originally Posted by olegd View Post
    I'm thinking of changing my 2012 Cayman Base to the Cayman R suspension. Can you share your experience with ride height and performance vs comfort on the street?
    Oct 2016
    Ontario
    255
    52
    I am very happy with X73. Car sits about an inch lower, which to me looks so much better! This car is just as awful on bumpy roads but it corners better and seems less bouncy.
    Cayman R Suspension Retrofit - New Top Mounts?-cayman-jpg
    Mar 2008
    1,757
    732
    694
    Thanks for the real would review!
    Jan 2018
    Thanks for the pic - the ride-height is perfect to me and I'm looking forward to installing them! What wheel and tire dimensions are you running in that pic, please?
    I'm aware of the subtle difference in the rear swaybar of the R (slightly stiffer) and don't think it's worth the investment. If I start doing trackdays, I may consider an adjustable rear, but my understanding is that the additional stiffness is there to balance out the LSD, which I don't have.
    Oct 2016
    Ontario
    255
    52
    18 inch rims and stock tire sizes (235/40/18, 265/40/18)
    Mar 2013
    Katy, TX
    896
    1859
    312
    Quote Originally Posted by markstudy View Post
    Bear in mine that mine's just a fair weather backroad toy, but I found the R suspension actually dealt with sharp stuff better than the S bits it replaced. Like maybe an unexpectedly tall expansion joint. I feel those with these 30 series tires, that’s for sure, but the susp swap helped with that sorta sharp stuff. And man does it handle well. Still has its S swaybars, too. If I came across a cherry set of R or Spyder wheels I’d likely take a go. More option for 19” rubber, a little more sidewall. One of these days!
    Ride height hasn’t been an issue. Just gotta be more mindful of it. Here's before and after.
    Cayman R Suspension Retrofit - New Top Mounts?-2e31b400-f21f-4b57-9fd6-3e44ade524df-jpg
    2011 CS / PDK / SportDesign Wheel / Sport Chrono Plus
    Carnewal GT CR exhaust / Fabspeed Tips / CR suspension
    19” O.Z. Leggera HLT / Michelin PS4S
    Jan 2018
    Thanks. I'm moving up to 18s from 17s at the same time (albeit with aftermarket wheels) and I'm planning to buy tires in the same size as OEM. So I have a good idea of how it will look now I've seen your setup :-)
    Oct 2016
    Ontario
    255
    52
    Here is another photo, wearing track shoes, also 18 inch but with slightly larger tires (245/40/18, 275/40/18)
    Cayman R Suspension Retrofit - New Top Mounts?-img_5374-jpg
    Jan 2016
    Washington
    704
    136
    The top mounts have a bushing that needs replacing, so for the amount of time you will invest in changing your suspension, I would recommend new top mounts. You will need an alignment as well as you have changed your ride height, so more negative camber front -1.0 and rear -1.2, 0 toe front, caster around 8 , rear toe in 1/32 on each side should keep your inside tire tread from wearing out.
    The negative camber will allow the full face of your tires to grip the road in the corners and prevent the outside of the tire shoulder from wearing. With 0 toe in front and just a little toe in in the rear, you should get about 17 - 20 k miles out of your tires unless they are very soft. I have 17k on my 3 year old Michelins PSS's with 5 autocross events and the tread is still above the wear bars. I have -1.6 camber in front and -2.1 in the rear, but am not using these any longer for racing.
    Jan 2018
    Does the Cayman R come with any sort of bump-steer parts to compensate for the 20mm drop? I haven't heard of any, but just checking there aren't any shims or different tie rods on the R compared to the base/S?
    Jan 2016
    Washington
    704
    136
    Quote Originally Posted by Alanine View Post
    My car is dropped 36 mm do to Tarett LCA's shims pushing out the tract to gain camber and Ohlins. So, I installed Elephant toe and bumpsteer adjustable links f&r to correct the arc of two different length link/arms at this dropped ride height.
  16. Remove Advertisements
  1. Cayman R Suspension -- Brand New Parts - SOLD
    By Lead Foot in forum Planet-9 Classifieds
    Last Post: 02-09-2015, 01:20 AM
  2. Cayman R suspension retrofit.... Anyone done it and unhappy with results???
    By Pittmd in forum 987 Cayman and Boxster Modifications
    Last Post: 01-20-2015, 10:49 PM
  3. Cayman R Suspension Retrofit - SOLD
    By DJRun135 in forum Planet-9 Classifieds
    Last Post: 09-06-2013, 04:30 AM
  4. CAYMAN R SUSPENSION RETROFIT -REDUCED! - No Longer Available
    By johndugaro in forum Planet-9 Classifieds
    Last Post: 01-29-2013, 07:10 PM
  5. CAYMAN R SUSPENSION RETROFIT - No Longer Available
    Last Post: 01-17-2013, 09:34 AM
