Leak found - please help! 987.2 Base Manual
Results 1 to 17 of 17
Thread: Leak found - please help! 987.2 Base Manual
    May 2019
    Hello! Need help with this leak! Any ideas of what to do / look for would be appreciated!
    987.2 base cayman 84k miles
    Manual
    I made quick YouTube video for better viewing:
    Part 1 (1:13) first view of leak and color
    Part 2 (3:07) top/bottom view
    Part 3 (1:24) deeper view
    Part 4 not yet filmed - will be after clean up!
    Part 1:
    https://youtu.be/uKG42WWrIM0
    Part 2:
    https://youtu.be/OE0fB2gq-mo
    Part 3:
    https://youtu.be/LKDENgBa1t8
    Jan 2019
    Re: Leak found - please help! 987.2 Base Manual
    It's hard to tell from the videos. My suspicions based on the general areas would be (1) clutch slave cylinder or (2) oil dripping from the engine air intake tube where the Mass Air Flow sensor resides (I assume that would be as a result of your AOS going bad and allowing a lot of oil into your intake and throttle body tube). These are educated WAGs so they're worth what you paid for them.
    Sep 2017
    VT
    100
    Check the brake fluid level. It it is the clutch slave cylinder (my guess as well) you will see that you are low - the brakes and the clutch share the same hydraulic reservoir . Does the fluid smell like brake fluid or oil?
    2009 Boxster Base
    Oct 2017
    Color definitely matches the brake fluid... not engine oil. Only other fluid color that is light yellow might be manual trans fluid.
    - 2013 Porsche Cayenne 3.6 - White/Beige - Premium Pack Plus, Pano, PDLS, LCA, 14-way, Walnut, PCM w/Bose, Quad Tips, Alum Pedals, WT Mats, etc.
    - 2010 Porsche Cayman 2.9 - Black/Black - Cayman S II wheels, Heated Seats, BiXenon w/DC, PCM w/SPP, Bluetooth/USB, All-Weather Mats, Clear Sides, X-pipe tips, Matte 'PORSCHE' emblem, Full interior LEDs, GT3 Brake Ducts, Ext. Leather Interior, etc.
    Apr 2007
    So. Cal
    562
    35
    have you taste it..? hydraulic brake fluid is pretty bitter and looking at the color most likely is hydraulic brake fluid.
    Based on the location you may have a leaking slave, which is not too expensive and fairly easy to replace…
    This would give you the opportunity to flush the entire system (brakes and clutch) I can see a Motive Bleeder in your future :-)
    May 2019
    Thanks for the info. Leak is still present. It is not oil. It is brake or transmission. The leak appears to be coming from or near the shifting cable that connects to the transmission. What is near there that could cause this? You mentioned the slave... where is that at?
    FYI it still leaks even if the car is parked
    Jun 2014
    IL
    417
    70
    Looks like enough fluid is leaking that if it is from the clutch line or cylinder your brake fluid level in the reservoir up front should be low. Or you could carefully top it off and then check level after a while. You could also compare taste between the brake fluid reservoir and the leak. Transmission fluid is very different, much thicker. I think your car has the 6-speed? Check out the article on bleeding the clutch cylinder here - that will show you where it's at: https://www.planet-9.com/reviews/ser...-cylinder.html
    May 2019
    Thank you @danschy
    After looking at that post I believe I am missing the rubber cap! Looking forward to getting back under the car!
    Sep 2017
    VT
    100
    The cap won't fix the leak. Most likely you have a bad clutch slave cylinder. If you are really lucky, the bleed valve is just open a fraction of a turn. I believe you need a very short handled 11 mm flare nut wrench to tighten the bleeder valve. It is a tight fit. Once you get the wrench on the bleeder valve there isn't much room to turn it.
    2009 Boxster Base
    Jan 2010
    3,051
    54
    49
    Quote Originally Posted by 987.2_fun View Post
    Thank you @danschy
    Mine is missing too. I noticed after the dealer service years ago and they said "there isn't a cap on the clutch slave". I knew they were BSing me but I left it that way. I doubt it matters.
    May 2019
    ok definitely the transmission! Good news...I do have a rubber cap! Bad news is that i don't believe the leak is from the bleeder! The clutch slave had plenty of liquid on it... part number 96211623700 - this came directly from part. Found one website from China that has it for $200. Is this a common thing or am I just lucky? Any other site you can suggest or upgraded replacement part?
    Jun 2014
    IL
    417
    70
    I have not heard that this is a common problem, so I guess you are lucky. I'm not sure about that number. A quick check on the sunsetporscheparts site yielded 9G2-116-237-01 for $112. Could also check out Pelican Parts.
    Dec 2015
    SF Bay Area, CA
    122
    Pelican Parts has a slave cylinder from Sachs (the OEM supplier) for $57. Confirm the brake fluid is low and then you'll be sure the slave is what's leaking.
    The rubber cap is just there to keep dirt out of the bleeder and is not critical. It's not uncommon for hydraulic cylinders to fail after a bunch of years. The rubber seals eventually go, or the cylinder internals get rusty if you don't bleed the fluid regularly.
    Apr 2007
    So. Cal
    562
    35
    Please do your car a favor and Don't buy any Chinese parts for your Porsche, there are plenty of reputable sources to get OEM parts like Pelican, Sunset Porsche, FPC Euro, etc.,
    Clean very well the entire area (I use simple green and rinse carefully with 'Low Pressure Water') to determine where the leak comes from, I would start by checking that the bleeder is tight (11mm socket), but don't overtight it..
    May 2019
    Lightbulb Re: Leak found - please help! 987.2 Base Manual
    @Gilles don't worry i won't buy from that site! I have had good experience with Sunset, Suncoasticon and Pelican!
    @gubi good find on that cheaper part! ty!
    @danschy thanks again for the insight!
    So it is a bit tight in there to work...will try that 11mm wrench. Called P-Dealership today. Quoted $410+tax for labor, parts on new slave install + transmission bleed. Considering that route...my hands are not huge, but i can tell that is a very small area to work in. I appreciate the comments! Nice to see a good online community...
    Apr 2007
    So. Cal
    562
    35
    Before you buy anything, you need to be sure what is exactly the cause of the leak…
    IMHO, you should first clean everything properly to confirm where the fluid is coming from, then you can decided if want to replace the part or get it done by someone else
    Aug 2013
    Massachusetts
    121
    Quote Originally Posted by Gilles View Post
    Wise words.
  20. Remove Advertisements
  1. Cayman S Sounds like exhaust leak after headers installed, but no sign of a leak. Any Ideas?
    By adamangkeona in forum 987 Cayman and Boxster Modifications
    Last Post: 11-30-2018, 03:52 PM
  2. Thoughts on Used 987.2 S vs. 987.2 Base vs. 981 Base
    By TNTide in forum 981 Cayman and Boxster Configurations and Ordering
    Last Post: 09-02-2018, 05:32 AM
  3. 2012 Base Carrera (manual) vs 2012 Cayman S or R (manual)
    By Thinking_man in forum Club 911 - General Discussion
    Last Post: 05-24-2012, 11:24 AM
  4. I found a Leak - now how do I fix it?
    By xamfed in forum 987 Cayman and Boxster Service and Tech
    Last Post: 09-12-2011, 12:49 PM
  5. Please help him !!...... coolant leak
    By Sandybelle in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 11-24-2008, 06:32 AM
