Developing problem with digital speedo
Results 1 to 4 of 4
Thread: Developing problem with digital speedo
    Mar 2006
    709
    Hi All,
    I have a growing problem with the digital [portion of the speedo on my 2007 Cayman S that I have owned since new.
    The problem is that there is a light hole in the dark portion of the digital speedo. It seems that the black coating is flaking off. It is right above the speed being displayed. You can see it in the attached photo right above and to the side of the "0" being displayed. I am concerned that the light hole will grow and interfere with the speed display, not to mention it just bothers me.
    Has anyone seen this before? Is this a dealer repair job only or can it be done at home? Degree of complexity?
    Thanks in advance for any help.
    Bill.
    Developing problem with digital speedo-img_5413-jpg
    formerly cebotech1
    Nov 2017
    Colorado
    Re: Developing problem with digital speedo
    Looks like you've got some pixels going/gone bad. Found a similar issue thread on here, but didn't seem to offer much help. Maybe you'll be able to find a local shop to fix your cluster. Either way, it's gotta come outta the car for repair/replacement. https://www.planet-9.com/987-cayman-...r-display.html
    2008 Boxster S
    Oct 2007
    Calif.
    903
    251
    59
    LCD is gone bad. There is no fix aside from replacement.
    BC
    4,809
    1064
    1177
    From the linked threads it might be a little expensive to fix, might consider living with it...
    2013 Boxster 981-S
    2006 Boxster Base
  7. Remove Advertisements
  1. dim digital speedo
    By kevinr in forum 987 Cayman and Boxster Electronics
    Last Post: 09-06-2011, 06:19 AM
  2. Cayman base speedo vs Cayman "s" speedo.
    By silvr987 in forum 987 Cayman and Boxster Modifications
    Last Post: 07-15-2011, 06:10 AM
  3. Xetronic Digital Kit Problem (HID kit)
    By ygfamily21 in forum 987 Cayman and Boxster Modifications
    Last Post: 08-05-2010, 11:35 AM
  4. Do you look at the Digital or Analog Speedo most?
    By sicshift in forum 987 Cayman and Boxster Chat
    Last Post: 03-12-2010, 06:30 PM
  5. look at your speedo or digital readout ?
    By vladie22 in forum 987 Cayman and Boxster Chat
    Last Post: 07-27-2007, 09:19 AM
