Emergency Run 987.2
Results 1 to 9 of 9
Thread: Emergency Run 987.2
    Feb 2013
    Central ill
    431
    66
    Emergency Run 987.2
    Had Emergency run light come on about 1 mile from home, turned car off was fine the rest of the way , drove to work same thing next day it kind of freaked me out, next day drove to Interstate Battery same thing on that trip turned car off the a mile later check engine light came on, battery tested really low 3 year old Moll battery, changed to Interstate H7 have driven about 60 miles no issues, Porsche battery quote $508 Interstate $178 .
    Nov 2017
    Colorado
    39
    Re: Emergency Run 987.2
    The OEM pricing on batteries are comical, regardless of brand. Picked up an H7 AGM from Advance last year for ~$160 after a 20 or 25% email coupon.
    2008 Boxster S
    Jan 2014
    SoCal
    832
    79
    189
    Yep, the computers on these cars freak out when the voltage gets too low. Battery check should be first on the list whenever weird messages pop up.
    Feb 2013
    Central ill
    431
    66
    Bad news got same message Emergency Transmission Run, then started running rough and got check engine light, maybe coil pack going bad, just changed plugs a few months ago and they all looked good.
    Feb 2013
    Central ill
    431
    66
    Had a misfire, changed all the coil packs, I am crossing my fingers.
    Dec 2014
    Malaysia
    1,395
    457
    224
    i had an experience with this before - is it the white one or red one? and did you get any codes?
    my tech previously diagnosed a dirty MAF as a cause.
    May 2015
    Orlando
    102
    57
    I had the emergency Transmission run message coming up when a coil was faulty. Replaced that and fixed the problem. Hope yours clears up.
    Feb 2013
    Central ill
    431
    66
    Mine was the white, if the new coil packs do not work will check the MAF, with only 34,000 miles I hope it is the the 9 year old coil packs I just changed.
    Feb 2013
    Central ill
    431
    66
    So far no more message after a few hundred miles since coil packs replaced, old coil packs look fine, live and learn just replaced plugs about 6-8 months ago.
  12. Remove Advertisements
