Brake Pads and sensors
Results 1 to 8 of 8
Thread: Brake Pads and sensors
    Mar 2019
    Hopefully not a completely stupid question but if it is I am a new Cayman S owner (2007). Just looking at the front brakes and noticed that is has a different shape wear sensor as compared to the brake pads I purchased (didn't know there were different types available). The ones on the car are the flat style with the rounded end. The brake pads I have take the round pin / cylinder type. Can I just change the sensor to match the pads or do I have to return the pads.
    Feb 2009
    Alberta
    2,863
    664
    1601
    Re: Brake Pads and sensors
    I've done brake jobs on my 911 and Cayman S. Both times I've tied off the sensors (and wrapped them in electrical tape to prevent water penetration) and tucked them up out of the way.
    Jan 2009
    52
    Should replace sensors when doing pads anyway as they wear also. I would try to find compatible sensors and if not return the pads and buy sensor and pads together. I guess as mentioned above you could just tie them off and watch the pad wear manually....
    Mar 2019
    I bought the pads from Pelican and they were listed for my car. Didn't realize the sensors were different until I pulled the wheel off. I went back on Pelican and checked the pads and they do show a sensor that fits the pads. I will check with Pelican on Monday to ensure the will work with my car. As far as I can tell the sensors is just a basic continuity circuits so as long as the cable fits the port on the car I should be good.
    May 2014
    Connecticut
    47
    I replaced all my pads with OEM pads and did not replace the sensors, just insulated and tied back the wires as others have done. Since I do autocross and track days, I keep a close eye on the pad and tire wear, so I don't feel like a need a sensor to tell me when he pads are low. I would normally replace them well before the sensor light comes on anyway.
    Tim
    Jun 2014
    IL
    425
    72
    Quote Originally Posted by cpgaylor View Post
    Should replace sensors when doing pads anyway as they wear also.....
    I assume the sensors would only wear if they make contact and trigger a warning. Right?
    Apr 2015
    Indiana
    789
    133
    181
    Quote Originally Posted by danschy View Post
    Yes you are correct. Sensors do not wear until the pads get pretty thin.. Problem is, they tend to fall apart when swapping pads. I ended up replacing the fronts. I too bought pads that the sensors did not fit. I returned the pads and bought Hawks that fit. Afterwords I decided it would be easy to do some grinding to make the sensors fit. I am happy with the Hawks though.
    Jan 2015
    Washington
    27
    Contact Pelican, they are really good about returns and can point you to the right sensors. But I too have just tied off the sensors. With some of the high friction pads don't even have holes for the sensors.
  11. Remove Advertisements
  1. Replies: 1
    Last Post: 07-01-2013, 12:07 PM
  2. 911 Boxster Cayman Brake Pads & Sensors - SOLD
    By Augie in forum Planet-9 Classifieds
    Last Post: 02-17-2013, 05:54 AM
  3. Brake dust and alternate brake pads
    By 123cayman456 in forum 987 Cayman and Boxster Modifications
    Last Post: 02-23-2012, 11:28 AM
  4. brake pads and brake fluids
    By christoscaymans in forum 987 Cayman and Boxster Service and Tech
    Last Post: 03-24-2009, 08:45 PM
  5. brake wear sensors with new pads
    By skittlz74 in forum 987 Cayman and Boxster Chat
    Last Post: 08-17-2007, 12:07 PM
