Cayman S Clutch hydraulic line damage
Results 1 to 2 of 2
Thread: Clutch hydraulic line damage
    Sep 2016
    GA
    I had a freak occurrence where something from the road got kicked up in the left side wheel well, tore into the plastic fender liner, and smashed the blue hydraulic clutch line that runs by there. All my fluid leaked out. This tube is about six feet long and comes through the body of the car at the master cylinder reservoir, goes along the inside of the wheel well and then curves under the car and goes to a connector back near the rear wheel. Any body know what the part number is? Not clear in the parts manual. Anybody replaced/repaired this line? Any ideas on the best repair method or just replace? Thanks
    Clutch hydraulic line damage-img_1092-jpgClutch hydraulic line damage-img_1093-jpgClutch hydraulic line damage-img_1095-jpg
    Sep 2017
    VT
    104
    Re: Clutch hydraulic line damage
    What year and model?
    2009 Boxster Base
  4. Remove Advertisements
  1. 'quick disconnect' on power steering hydraulic line
    By Gilles in forum 987 Cayman and Boxster Chat
    Last Post: 12-27-2011, 11:13 AM
  2. Disconnected Hydraulic Oil line hose?
    By golfguy11800 in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 06-07-2010, 07:09 PM
  3. M96/23 Hydraulic Lifter Failure, with pics
    By [email protected] in forum 987 Cayman and Boxster Service and Tech
    Last Post: 01-08-2009, 08:56 AM
  4. Hydraulic fluid leak
    By Bodine in forum Porsche Care and Detailing
    Last Post: 11-13-2007, 06:08 PM
  5. 'quick disconnect' on power steering hydraulic line
    By in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 12-31-1969, 07:00 PM
