Boxster S 2005 Boxster S - Intermittent charging issues
Results 1 to 9 of 9
Thread: 2005 Boxster S - Intermittent charging issues
    Jun 2019
    2005 Boxster S - 987, 3.2 L.
    I have owned my 2005 Boxster now for 1 month. i have an intermittent charging issue. Sometimes my charging is low (13.2) the dashboard warning comes light goes. When its charging properly its at about 14.1V and no light. When it isn't charging i can tell because the restarts are very very slow. I assume that if it was an alternator or voltage regulator it would be all the time. Any suggestions
    Jun 2014
    IL
    447
    74
    Re: 2005 Boxster S - Intermittent charging issues
    Is it load related, i.e., does voltage drop when you have lights or other high current accessories on and are idling, or does it just happen randomly irrespective of load / engine speed? If load / engine speed related you may have lost an alternator diode (reduced charging capacity). Otherwise it may be a loose connection somewhere, ground or power, that sometimes makes a poorer connection.
    2007 Cayman
    1974 914 2.0 | sold
    Jun 2019
    Thanks danschy for reaching out! It happens randomly irrespective of engine load / speed. Aside from removing the alternator, is there anything i can check to see if its the alternator or not?
    Mar 2009
    2,170
    836
    620
    How old is your battery? I'd have that checked first. You could have a cell failing. And failing batteries in our cars cause all kinds of weird things to happen, unlike most cars.
    Jun 2019
    1 month old
    Mar 2009
    2,170
    836
    620
    Quote Originally Posted by [email protected] View Post
    1 month old
    Get it checked any way. You wouldn't be the first to get a brand new battery that was faulty. It's happened to me twice in my driving history.
    Jun 2019
    I checked the battery, it checked out fine. i went out last nite and drove around for an hour or so. When i got home i checked the charging, it was charging at 13.1-13.3 volts, the meter was jumping around with the range mentioned. THE WEIRD THING IS THAT MY "BATTERY/CHARGING" LIGHT ON THE DASH DID NOT COME ON. i ordered a voltage regulator and when i get the problem, again i will try it. Not sure whats going on.
    Jun 2019
    ** UPDATE *** I had the alternator checked, it was good. I found a loose ground wire from engine to chassis. its now 14.2 Volts. Thank God, I found the problem!!
    1,570
    104
    261
    Thanks for sharing your solution. It's certain to help someone else down the road who experiences similar symptoms. I'm glad it was a simple fix!
    Best regards,
    Croc'ed
  12. Remove Advertisements
