Engine Removal Question - Page 8
Page 8 of 8 FirstFirst ... 678
Results 141 to 159 of 159
Thread: Engine Removal Question
  1. #141
    Nov 2012
    Saskatchewan
    56
    Re: Engine Removal Question
    Thanks for the support guys. Here is the latest 2 hours of progress. it's not all that exciting, but if you were removing engine and wanted to see how to do it, might be helpful.
    03
    https://www.youtube.com/watch?v=l_7c...ature=youtu.be
    04
    https://www.youtube.com/watch?v=03-E...ature=youtu.be
    05
    https://www.youtube.com/watch?v=83b6...ature=youtu.be
    06
    https://www.youtube.com/watch?v=N5N4...ature=youtu.be
  3. #142
    Nov 2012
    Saskatchewan
    56
  4. #143
    Oct 2010
    1,261
    130
    500
    99
    Good progress Nick. When you put the engine back together I would treat it to a new oil cooler since it might not be possible to get all the bits out of the old one.
    Good luck,
    Rob
    2014 Mazda 3 DD
    2015 Cayenne Diesel
    2016 Spyder
  6. #144
    Nov 2012
    Saskatchewan
    56
    Here are the latest videos
    engine rebuild 12
    https://www.youtube.com/watch?v=83pacLf3pQc
    engine rebuild 13
    https://www.youtube.com/watch?v=1NKaz3heMP8
    engine rebuild 14
    https://www.youtube.com/watch?v=0jUbOdUQOeo
    engine rebuild 15
    https://www.youtube.com/watch?v=SyhV3K4VtNU
    engine rebuild 16
    https://www.youtube.com/watch?v=EBMTjpupBO4
    engine rebuild 17
    https://www.youtube.com/watch?v=aXBJ63_mPb0
    engine rebuild 18
    https://www.youtube.com/watch?v=2YVZk4wMBe0
    engine rebuild 19
    https://www.youtube.com/watch?v=d-VXkkXR_8o
    Intake and exhaust camshafts on both banks looked OK.
    Hydraulic lifters looked OK.
    Heads looked OK.
    Cylinder walls and pistons look OK (from top).
    bank 1-3
    bank 4-6 some very minor scuffing but hardly enough to grab finger nail
    so now I have to work on taking apart the engine block itself. Maybe one of the bearings in here got damaged and is what caused the metal pieces.
  7. #145
    Nov 2012
    Saskatchewan
    56
    Hi Guys,
    So here is the latest.
    engine rebuild 20
    https://www.youtube.com/watch?v=37I12-gT1AM
    engine rebuild 21
    https://www.youtube.com/watch?v=WrtTp9jVu7c
    engine rebuild 22
    https://www.youtube.com/watch?v=iMiHlor7t_A
    engine rebuild 23
    https://www.youtube.com/watch?v=7jx6UdP_KF0
    engine rebuild 24
    https://www.youtube.com/watch?v=KPAyqdDMIio
    engine rebuild 25 (this one shows an overview of damage)
    https://www.youtube.com/watch?v=l0MtjdCfEzE
    and pictures
    So let me know what your thoughts are. I would like to know what you guys think caused this. I think it may have been the cold start and having no oil by-pass. Also, is this damage too extensive and need new pistons and re-sleeve, or OK to re-assemble with just new bearings?
    For comparison. This is what I did the first time;
  8. #146
    Oct 2010
    1,261
    130
    500
    99
    Nick
    I was wondering if you reused the oil cooler and it had junk in it from first upset. I would show your pictures to LN to get their opinion. My feeling is you need to get rid of all scored pieces or you will be burning oil. I don't recall but did you crank engine with no fuel to get oil flowing?
    Good luck
    Rob
  9. #147
    Feb 2013
    Fort Worth, TX
    570
    389
    81
    Jake Raby (Flat6 Innovations) sees quite a few engines that have failed in cold environs. I won't speculate to the cause but you may want to include him on your emails with LN and search Rennlist with what he has to say about it.
    2006 Cayman S- Numeric Cup style Cables, ARP rod bolts, LN Engineering IMS retrofit, Mantis deep sump, IPD Competition plenum, GT3 throttle body, FVD software, Evoms V-flow air intake, Tubi style catback, Numeric short shifter, third radiator, GT3 brake ducts, Elephant Racing LCAs, Tarrett sway bars, DSC Sport, Tractive suspension
  10. #148
    Sep 2009
    IL
    42
    Quote Originally Posted by Rob VN View Post
    Nick
    Good luck
    Rob
    This is exactly what happened here. Nick was in communication with Jake and yes, he admitted to reusing the oil cooler after the original failure when the cooler should have been replaced. This same phenomenon has been occuring for years even in aircooled cars - engine fails, is rebuilt, and oil cooler lines and cooler aren't pulled and replaced.There are literally tens of thousands of spin on filter adapters used in M96, M97, and 9A1. Also, every Flat 6 Innovations engine comes with one, even those used on the track. Lack of a bypass is not the issue here. If anything, the spin on oil filter adapter limited the amount of collateral damage since it has no bypass.
    This kind of damage can also occur when an engine is run with broken rings. There are other things that can also lead to system wide damage like this, including, but not limited to, improper cleaning of the bores as the honing oil is mixed with nikasil dust and is liquid death.
    Charles Navarro
  11. #149
    Nov 2012
    Saskatchewan
    56
    Hello Everyone!
    Thought I would finally give an update on this whole project of mine. I ended up completely taking apart the engine again in 2016 and reassembled it at the end of 2016. I didn't want to call it a success until I had at least 10,000km on the new-new rebuild. This summer I drove out to British Columbia (from Saskatchewan) and back and I now have about 12,000km on my 2nd rebuild! So I think I can call it a success now.
    I re-used the same block and pistons. They had very slight scuffing from the oil issue on my first rebuild. I put 5,000km on and had it go down 2 segments on the oil level. So 0.8 litres of oil consumption which I think is normal.
    I took videos of the whole rebuild process. Its 70 videos that are all about 20 minutes long. When I get a chance, I am going to upload them.
    That's all I have for now (until I upload the 70 odd videos). Felt like I was leaving you guys hanging by never posting what happened. As a lot of you were a super big help!
    Cheers,
    Nick
  12. #150
    Oct 2010
    1,261
    130
    500
    99
    Congratulations Nick. You have perseverance for sure.
    Rob
    2014 Mazda 3 DD
    2015 Cayenne Diesel
    2016 Spyder
  13. #151
    Feb 2013
    Fort Worth, TX
    570
    389
    81
    Quote Originally Posted by guglido View Post
    Hello Everyone!
    Cheers,
    Nick
    Glad to see you got it back together and going again. Here's too many miles of happy motoring
  14. #152
    1,609
    108
    273
    62
    Terrific news! Maybe post the videos to YouTube and insert links to them here. I foresee binge watching in my future...
    Best regards,
    Croc'ed
  15. #153
    Oct 2009
    347
    63
    can't wait to watch the videos, it will be helpful if my M97 ever lets loose, thanks!!
  16. #154
    Apr 2015
    Indiana
    803
    137
    183
    Wow, I have been waiting for years to see this post. Great that you got it done.
  17. #155
    Nov 2012
    Saskatchewan
    56
    So here it is! The Playlist of all 68 videos. From crank assembly to mounting transmission.
    It might not be the greatest of videos, I block the view sometimes. But if someone is interested in doing something similar, they can see all the steps I went through.
    All 68 videos in a playlist. I gave my internet a workout this weekend.
    This is the link to playlist. Doesn't seem to work when viewing on mobile though.
    https://www.youtube.com/playlist?lis...aS6vA1Tzha0G2c
    First 3 videos
  18. #156
    Jun 2016
    Charleston, SC
    278
    48
    I came late to this party! Got my Boxster couple of years ago and just saw this thread today. I spent most of the day reading and watching all the the postings.
    The only thing I can say is WOW!!!!!!!!!! JUST WOW!!!!!!!!!!
    I absolutely admire your dedication, persistence and bravery! I have done some pretty crazy stuff in my life, but you are my hero!
    Did you come to a final conclusion of what caused the second failure?
    Thank you for all of your hard work and posting all of this. Huge benefit and great learning for me and I think for all of us.
    Good luck!
  19. #157
    Apr 2018
    TX
    Great thread, and posts. Outstanding you had the courage to tackle this solo and then document. You ever make it to Houston, I will buy you a beer, or 20.
    Thank you!
  20. #158
    Aug 2019
    I have never rebuilt an engine and had ideas that I might do it someday, but I might just limit that to an LSX if I ever go there. Now, I am sure I would not try my hand at rebuilding a newer Porsche engine after looking at the costs and estimating how much money I could generate working with all of the time it would take instead. I was looking on BGB's site at 3.8l conversions a few days ago and thought it was a good deal, but now I know it is a great deal since I don't have to anything beyond drop off, pay, and pick up. This absolutely epic thread was the voice of reason for me. I am thrilled to see it all worked out in the end, you gained an experience that you will never forget as long as you are of sound mind and what an incredibly generous contribution to this community from someone who would not appear to be a likely source for this type of thing, but no Porsche rebuilding for me, none. guglido, you definitely have no shortage of courage and resilience. See sig line...
    Stubbornness is a virtue...
  21. #159
    Jul 2019
    49
    I have read the entire thread from post 1 till now in one sitting. My jaw dropped to the floor when you found metal shavings in the oil after putting it all back together! I imagine the level of mental tension behind all of this. Big thanks for your documentation and good luck!
  22. Remove Advertisements
  1. HIP clear engine cover question
    By ccw1982 in forum 987 Cayman and Boxster Modifications
    Last Post: 01-18-2011, 05:34 PM
  2. Steering Wheel Removal Question
    By binky in forum 987 Cayman and Boxster Modifications
    Last Post: 10-20-2009, 10:32 AM
  3. Engine removed
    By ul2fly in forum 987 Cayman and Boxster Chat
    Last Post: 12-08-2008, 08:04 AM
  4. EVO intake install and stock air filter removal question
    By gmsracing in forum 987 Cayman and Boxster Modifications
    Last Post: 05-14-2008, 01:37 PM
  5. Instrument cluster removal question
    By eslai in forum 987 Cayman and Boxster Chat
    Last Post: 11-15-2007, 01:25 AM
