Changing the date
Results 1 to 6 of 6
Thread: Changing the date
    Nova Scotia
    223
    Changing the date
    My 2008 GTS shows the date one day later than current (it is showing today as the 25th but it is the 24th). I see the place in the PCM menu to theoretically change it, but there is no actual place to do this. I can change the date format but not the date. Anyone have any ideas? The owner's manual shows exactly what is on the PCM display, so I don't think that I am missing something.
    Kim
    2014 Cayenne Diesel
    2008 Cayenne GTS
    the Glimmer Twins
    BC
    4,855
    1072
    1190
    Re: Changing the date
    Quote Originally Posted by Kim from Canada View Post
    A day out sounds like the year is wrong...
    2013 Boxster 981-S
    2006 Boxster Base
    Nova Scotia
    223
    Fair enough. Any idea how to change the year?
    Kim
    2014 Cayenne Diesel
    2008 Cayenne GTS
    the Glimmer Twins
    BC
    4,855
    1072
    1190
    Sorry, I don't have access to a copy of the PCM manual for a 2008 Cayenne, but from what I did see there should be a Date/Time section in the Settings menu. Also if you have it set to GPS time synchronization you cannot set the time.
    do you have the PCM manual?
    2013 Boxster 981-S
    2006 Boxster Base
    May 2019
    I'm experiencing the same thing with my '04 Cayenne Turbo - date reads 3/23/2002 ........and while I can change the time, time zone, 12/24 hr format, or date format, nothing anywhere allows for a date change. Porsche mechanics looked at it, fiddled with the PCM and said "It should correct when the GPS updates" ....NOT! A second mechanic came out and said he'd never seen anything like that before and their final comments were "Nothing we can do" ........but....there's gotta be a way!!!!
    Nova Scotia
    223
    an exact description of my issue. My date is only 1 day off, however, it always shows tomorrow's date.
    Kim
    2014 Cayenne Diesel
    2008 Cayenne GTS
    the Glimmer Twins
  9. Remove Advertisements
  1. Throttle Response While Changing Gears
    By Stevie in forum 987 Cayman and Boxster Chat
    Last Post: 04-26-2017, 04:52 PM
  2. Replies: 2
    Last Post: 01-29-2016, 01:16 PM
  3. Changing your Brake Fluid Article
    By K-Man S in forum 987 Cayman and Boxster Service and Tech
    Last Post: 02-23-2007, 03:08 PM
  4. Articles changing their tone?
    By PACayman in forum 987 Cayman and Boxster Chat
    Last Post: 01-04-2006, 07:10 AM
  5. Build date/delivery date?
    By Santa Fe in forum 987 Cayman and Boxster Chat
    Last Post: 11-25-2005, 11:01 PM
