Fuel High Pressure Fluctuates - are these actual values normal or problematic?
Results 1 to 1 of 1
Thread: Fuel High Pressure Fluctuates - are these actual values normal or problematic?
    Mar 2019
    Hi all,
    I have a 2008 Cayenne S, 4.8, V8. 125,000 miles
    The check engine light lit up today. I used my Durametric and found two error codes...
    1027 : Fuel High Pressure Fluctuates
    2181 : Cooling System Performance
    From what I have read today, the former is perhaps the culprit for the check engine notice, whereas the latter would result in the 'Service Now' message rather than check engine.*I did have Service Now displaying already but my Porsche repair guy told me it indicates periodic maintenance is due, such as 60\90\120, and that it could only be cleared by Porsche dealer. Having looked into that more today, I'm not certain he is correct but given all these things, I am choosing to resolve the fuel code first. I suspect the HPFP might be bad so I monitored actual values with the Durametric. Noting that fuel pressure setpoint is 40bar, there are significant pressure deviations above and below; from what I observed it was ranging about 37 - 41 bar approximately. Before I buy a new HPFP and perform replacement, can any of you folks tell me what the threshold from setpoint is to trip the code? Are my observed actual value ranges normal or problematic? See screenshots.
    Thanks in advance.
    Fuel High Pressure Fluctuates - are these actual values normal or problematic?-duramet-short-test-jpgFuel High Pressure Fluctuates - are these actual values normal or problematic?-hpfp-fluctuation-jpg
  1. Replies: 0
    Last Post: 05-03-2013, 03:00 AM
  2. Can Anyone Help Interpret Durametric Actual Values?
    By Mr_Brown in forum 987 Cayman and Boxster Service and Tech
    Last Post: 05-01-2012, 10:14 AM
  3. Is this really problematic?
    By zksk10 in forum 987 Cayman and Boxster Chat
    Last Post: 09-24-2011, 11:56 PM
  4. High Pressure Fuel Pump Recall
    By DaveC in forum Club 911 - General Discussion
    Last Post: 08-01-2011, 07:55 AM
  5. High Octane Fuel: Q&A With Rockett Brand Race Fuel
    Last Post: 07-29-2007, 11:25 PM
