confused... Are the adaptive motor mounts standard?
Results 1 to 8 of 8
Thread: confused... Are the adaptive motor mounts standard?
    Dec 2015
    Hi all. Some docs seem to imply that you have to get the sport chrono package to get the
    adaptive motor mounts. Is that true?
    Thanks!
    Dec 2012
    CPa
    2,614
    5575
    1213
    Re: confused... Are the adaptive motor mounts standard?
    Quote Originally Posted by JoeWeinstein View Post
    Thanks!
    Hi Joe.
    That is what I remember. Such being maybe the only reason I ponied up for the sport chrono on LG.
    Rob :-)
    "Happiness is but a thought away"
    _______________________
    2013 981B S Lime Gold/Espresso, MT, Many Ops; My Garage 4/4/2013.
    Nov 2015
    357
    49
    120
    Yes, sport chrono is required and in the 981 it's active transmission mounts, not engine mounts. The 991 gets active engine mounts. It has to do with the suspension geometry and the location of the mounts.
    2015 Boxster GTS
    Previous Porsche's: 2003 Boxster S, 2004 Cayenne TT, 1989 911 turbo, 1984 944, 1979 911SC, 1974 914 (my first Porsche)
    Previous Interesting Rides:2014 Corvette Z51. 2012 Jeep SRT8, 1996 Corvette LT4
    Dec 2015
    The Porsche car configurator doesn't mention anything about transmission mounts when describing the Sports Chrono package...
    "Comprising an analog stopwatch on the dashboard, a digital stopwatch function in the instrument cluster, the Porsche Track Precision app and preparation for a lap trigger. The Porsche Track Precision app enables your driving stats to be displayed in detail, logged and analyzed on your smartphone. The lap timer can be stopped manually using the control stalk for the Sport Chrono function automated by GPS or, for even greater precision, by means of the optional lap trigger available from Porsche Tequipment. You can then compare your lap times on your smartphone. The app also visualizes driving dynamics, presents a video analysis and allows you to manage the logs, circuit profiles and driver profiles on the smartphone device. Note: use of the app permitted on closed land only. For information on compatible mobile phones, please visit Official Porsche Website - Dr. Ing. h.c. F. Porsche AG or consult your Porsche Center. Notes: additional performance display on integrated 7-inch color touchscreen in conjunction with Porsche Communication Management (PCM). Available from 02/2015"
    Nov 2015
    357
    49
    120
    Check out this link: Porsche Cayman - Dynamic transmission mounts - Porsche Cars North America or Porsche Boxster S - Dynamic transmission mounts - Porsche Cars North America lest you think it's only on the Cayman.
    Dynamic transmission mounts are included as part of the optional Sport Chrono Package. They are designed to enhance both performance and comfort.
    The electronically controlled system minimizes the oscillations and vibrations of the entire drive train, especially the engine.
    The transmission is bolted to the body by two mounts. Like any mass, it obeys the law of inertia. This means that it will continue moving in a uniformly straight line unless some force causes it to change direction. Put more simply: when you are driving into a bend, the vehicle will follow your steering but, at first, the mass of the drive train will not. This means that the rear of the vehicle will ultimately be pushed outwards as a result of the drive train’s force of inertia.
    Dynamic transmission mounts minimize this effect. Steering angle and both longitudinal and lateral acceleration are constantly recorded by sensors. The stiffness and damping performance of the transmission mounts adapt to changes in driving style and road surface conditions, which is achieved by use of a fluid with magnetic properties. This results in greater traction, perceptibly more stable handling under load change conditions and in fast corners and, in conjunction with the ‘Launch Control’ function for example, extremely fast acceleration.
    Using the SPORT or SPORT PLUS button you can switch the dynamic transmission mounts from ‘Normal’ to ‘Sport’ or ‘Performance’ mode and intensify your driving pleasure.
    In conjunction with optional PCM, the G-Force graphic on the TFT screen in the right-hand circular instrument enables you to view the lateral and longitudinal forces as they act on the vehicle.
    2015 Boxster GTS
    Nov 2008
    Houston
    1,042
    208
    OP- are you asking about the GT4? If so, dynamic gearbox mounts, PTV, PASM are all standard. Sport Chrono is the dash clock and the precision track app. The drive train is not changed with SC option. I thought it was a bit pricey for the track app and have heard mixed opinions about the app. I have an AIM solo DL already so didn't spec the SC option.
    2008 911 Carrera S (sold)
    2009 Cayman 2.9 (sold)
    2012 Cayman R
    2004 Boxster S
    2015 GT3
    Nov 2015
    357
    49
    120
    Quote Originally Posted by zedcat View Post
    ah, I didn't notice the GT4 specific forum, I was browsing using new posts. Yes, they are standard on the GT4
    Porsche Cayman GT4 - Dynamic gearbox mounts - Porsche Cars North America
    2015 Boxster GTS
    Dec 2015
    Yes, thanks all. I am asking specifically about the GT4, so I now understand that I get all the chassis goodness standard, and that
    for the extra $1,600 or so bux, all I get is the stopwatch on the dash and the app. I will not be needing the app, as I will be
    getting a race-technology 20hz GPS datalogger with video integration. Wid'ya Zedcat!
    Oh, and I'm getting their OBDII ECU connector so the datalogger can record the RPM, steering angle, brake and throttle etc!
  11. Remove Advertisements
  1. Just to confirm-- current 981 motors are the MA1 structure??
    By D&D in forum 981 Cayman and Boxster Configurations and Ordering
    Last Post: 02-22-2015, 08:49 AM
  2. Replies: 8
    Last Post: 07-29-2013, 10:22 AM
  3. How good are the standard headlights?
    By Denis54 in forum 987 Cayman and Boxster Chat
    Last Post: 10-02-2007, 09:30 AM
  4. Here are the Order Status Codes
    By Brian (NC) in forum 987 Cayman and Boxster Chat
    Last Post: 09-25-2005, 07:02 AM
  5. Are the side vents the same on Boxster and Cayman?
    By raceboy in forum 987 Cayman and Boxster Chat
    Last Post: 09-17-2005, 10:47 AM
