Good machine shop or help with cleaning up threads in Vancouver area
Results 1 to 9 of 9
Thread: Good machine shop or help with cleaning up threads in Vancouver area
    Feb 2016
    BC
    82
    27
    Hi,
    Wondering if anyone in Vancouver can help me. I've got a 2015 981 Cayman 2.7.
    My issue is that one of the bolt holes in the steering rack which holds the steering rack to the subframe is now threaded. I figured this out when chasing down a vibration when going over bumps and slightly turning the wheel at parking lot speeds and slightly turning the wheel from side to side at speeds greater than 100 kmh. After removing the cover panel for the front subframe I noticed that one of the bolts holding the steering rack to the subframe had backed out on its own. And then when I removed this bolt, there were some shavings that came with it. Also, when tightening the bolt at some point it would become loose again.
    I'm thinking of getting it rethreaded, maybe making the hole bigger to accommodate a bigger bolt or getting a threaded rod welded into the bolt hole and secure the rack to the subframe with a nut instead. Anything short of replacing the rack as it is quite costly for just the bolt hole..
    I am hoping someone can point me in the right direction on where I can get this sort of work done around the GVA.
    Thank you! I would greatly appreciate any help.
    Iggy
    May 2008
    IN
    2,428
    40
    Re: Good machine shop or help with cleaning up threads in Vancouver area
    Take a look at Time-sert to repair the threads. I've installed them with hand tools. Basically drill, tap and install.
    Les
    Feb 2016
    BC
    82
    27
    Quote Originally Posted by Greywolf View Post
    I'm not sure if I have enough space bigger threads? Do you have a link to what I might need? A lot of things are popping up for time-sert.. thanks!
    Sent from my Pixel 2 using Tapatalk
    Jul 2016
    ON
    35
    Not a big deal. You could do a Timesert ++ TIME-SERT Official Threaded inserts for stripped threads, blown out sparkplugs,
    If you are not comfortable with doing this yourself, I would trust Scan Automotive Scan Automotive - North Vancouver Porsche Specialist
    Good luck
    May 2008
    IN
    2,428
    40
    FFaust linked the product I was referring to.
    Les
    Oct 2009
    345
    62
    I did the exact same thing to my subframe bolts. I bought a tap and die set from Harbor Freight and cleaned up the threads on the bolt and recut the subframe threads. Its not a hard job.
    Feb 2016
    BC
    82
    27
    Thanks guys. I think I'll go with the time sert option. I just got a thread pitch gauge to measure the bolt.
    I've just never done this before, but like anything else on this car, I haven't really done much before haha.
    Feb 2016
    BC
    82
    27
    Ummm this might be the actual culprit of the vibration .. tell me if you guys think this is how aftermarket control arms are supposed to be.. never had them before so I don't know better
    https://youtu.be/6NLw2lvNrt0
    Jul 2016
    ON
    35
    Does indeed seem awfully loose, and could be the cause of the vibration.
  12. Remove Advertisements
  1. Good shop for corner balance and alignment in Bay Area?
    By themperor in forum 987 Cayman and Boxster Modifications
    Last Post: 09-16-2014, 10:53 PM
  2. Vancouver area ferries
    By BcaymanS in forum Great White North Region
    Last Post: 05-13-2011, 08:35 AM
  3. Clear Bra Installer In Vancouver / Lower Mainland Area
    By deltacs in forum U.S. Northwest Region
    Last Post: 04-15-2008, 02:50 PM
  4. Need a recomendation for a good body shop in Boston area
    By Apollo in forum U.S. Northeast (Nor'Easters) Region
    Last Post: 04-15-2008, 09:26 AM
  5. Good Paint Shop in San Francisco Bay Area?
    By ciopyk987s in forum U.S. West Region
    Last Post: 05-05-2007, 12:35 PM
