981 & 991 Door panel removal
Results 1 to 4 of 4
Thread: 981 & 991 Door panel removal
    Jul 2009
    23,137
    86
    Post 981 & 991 Door panel removal
     (https://www.planet-9.com/reviews/miscellaneous/p455-98126amp-3b-991-door-panel-removal.html)
    by: Ken B
    Description: This is how to remove the Inner door panel on the 981 Boxster and Cayman. It also appears to be similar on the 991 911Interior Door panel removal Tools required: #30 TORX screwdriver or equivalent, plastic panel tool set. (soft plastic pry bar) All these tools are available from the local AutoZone and Pepboys. I have seen them in Harbor Freight as well. ALWAYS Safe the vehicle and disconnect the Negative on the battery before starting work on a job like this. One stray static charge canset off your airbag system and ruin your day.Attachment 303531. Removethe plastic cover that says AIRBAG (this is just a cover not the airbag) Attachment 303542. Start gently prying on it from the door edgewhere you see my hand and work your way around. Attachment 303553. Once it’s off there are these rubber tophatshaped grommets. Attachment 303564. Make sure you have them both for reinstallation Attachment 30357Door handle cover Attachment 30358Pry on the inside edgeAttachment 30359Lift outAttachment 30360Triangle CoverAttachment 30361Pry up on the bottom edge wiggling it gentlyAttachment 30362Once it’s up tilt it forward Attachment 30363 Attachment 30364Note that there is a hook its pretty flexible plastic butyou have to work it out of the hole.Attachment 30365Remove the end panel cover, Pry gently on the outer edge Attachment 30367Attachment 30368 Attachment 30366Attachment 30374Using a Number 30 TORX screwdriver or bit remove 4 boltsAttachment 30375One bolt behind the aft coverAttachment 30376Behind the door handle coverAttachment 30379Attachment 30377Attachment 30378Two bolts behind the AIRBAG coverAttachment 30380Lift Door panel straight up about 1 to 2 inches. It needs toclear the hooks on the inside Attachment 30381Attachment 30382Unclip the white part of the door handle cable. Then slide the white part aft and then out Attachment 30383Now rotate the cable till the round end comes outAttachment 30386Press blue tab on wire harness connectorAttachment 30387Attachment 30388Rotate pink clip Attachment 30389Slide harness out of receptacleAttachment 30390 Attachment 30391Attachment 30392 Now that the Door cover is off inspect all these rubber grommets to ensure you didn't loosen one while lifting the door panel offAttachment 30394You can see the airbag assembly at the top of the inner panelAttachment 30395The silver tube at the top is the airbag CO2 cartridge and firing mechanismAttachment 30396Sorry picture is turned but you can see the control unit that is in the door and the woofer of the Bose stereo.
    Jul 2009
    251
    Re: 981 & 991 Door panel removal
    This is a keeper! Moderator, please save this and the attachments so they don't disappear (unlike the old 987 dyno plots I wish we still had access to).
    Mar 2013
    Idaho
    1,500
    909
    664
    Any way we can get this thread updated? Looks like the "More..." link is broken. And probably a cleaner way to organize the info above. Found myself mistakenly clicking on the same photo multiple times.
    2014 981B
    Sapphire Blue, Luxor, Premium, PDK, PASM, PTV, Bose, 19" BS wheels, Sport Design SW, 14W seats, ACC, ParkAssist, LDP, folding mirrors
    Feb 2017
    PA
    The links to the pictures for your post on how to remove the door panels on a 981 do not work.
  7. Remove Advertisements
  1. 981 Inner Door Panel removal
    By Ken B in forum 981 Cayman and Boxster Modifications
    Last Post: 05-21-2018, 06:48 PM
  2. Door Panel Removal
    Last Post: 02-17-2014, 12:37 PM
  3. Door Panel Removal
    Last Post: 11-16-2009, 10:40 PM
  4. Door Panel Removal
    By mlsnod in forum 987 Cayman and Boxster Chat
    Last Post: 10-16-2007, 08:59 PM
  5. Door Panel Removal
    By mlsnod in forum 987 Cayman and Boxster Service and Tech
