more wear on the inside of front tires?
Results 1 to 15 of 15
Thread: more wear on the inside of front tires?
    Jan 2016
    374
    42
    85
    My fronts are lasting OK, but the inner tread is considerably more worn than the center and outer. The miles are about 50-50 between normal highway and very curvy highway, with long curves that pull .5-.7G at 60+ mph, unscientifically. I used to run a lot of very tight roads, all 2nd gear, and "drive outside the envelope of my alignment" according to old sage tire dude, but these tires have only seen the spirited commute, for the most part.
    Pressure has been 33psi cold (Boxster S 981 spec) but up to 36psi by the time the fun starts.
    Thanks for any thoughts.
    2013 Boxster S acquired late Dec 2015.
    Platinum Silver w/ Black, 20" Carerra Classic wheels, SC, BOSE, PSE, SportDesign wheel.
    4,818
    372
    1812
    Re: more wear on the inside of front tires?
    Have you checked the camber? Excessive camber in the front suspension can cause wheels to lean too much to the inside thereby putting too much load on the inner side of the tire.
    Aug 2006
    1,388
    203
    Quote Originally Posted by fast1 View Post
    or check the front toe setting.
    2013 981S/Sport suspension/PTV/6 spd/
    2006 987--sold
    1999 986--sold
    Jun 2014
    Chesapeake, Virginia
    802
    80
    156
    Quote Originally Posted by Mike_in OH View Post
    Yeah, this sounds like front toe out. It's not necessarily intuitive, but a little negative camber doesn't impact wear much, but add a little toe out and the inside corners will just disappear. Have your alignment checked and have your front toe changed to neutral or a little toe in.
    Jan 2016
    374
    42
    85
    Quote Originally Posted by sjfehr View Post
    Totally makes sense, and thanks to all. Got it: good alignment shop.
    Feb 2013
    British Columbia
    620
    131
    103
    Please post what you find from the alignment shop.
    2014 Cayman S
    2000 Boxster S (Boxster owner since 1997)
    2000 911 Carrera lapping toy
    PCA National DE Instructor
    Jan 2016
    374
    42
    85
    A little update. Good mechanic and good alignment shop next door both agreed that the wear wasn't alarmingly uneven and that I should get new tires. Ordered today, having them put on by the alignment shop and will ask them to do an alignment check. I expect to stay with stock settings.
    Not dramatic, but gave me full-on motivation to order a new set of PS4S. Pretty excited about that.
    May 2016
    Ks
    a bit late to the thread but I would suggest more autox or track time to get some wear on the outer shoulder
    Jan 2016
    374
    42
    85
    Quote Originally Posted by dingosatemy981 View Post
    Well said! I do have a "1.0G commute" though. But it's not lock-to-lock turning.
    Sep 2006
    786
    49
    Quote Originally Posted by trickybit View Post
    If you stay with the stock alignment setting and that is what it is now you will continue to get uneven wear. The Porsche's normally run a little more negative camber than most to improve turn in response and to make the tires lay flatter when pushed into the corners. The downside is wear on the inside shoulder. You can always run a little less negative front camber.
    Jan 2016
    374
    42
    85
    Thanks, Jim. Recent input suggests they weren't too unevenly worn; the other grooves were close behind. I just dropped off the car at a highly-regarded alignment shop to get my new PS4S mounted (drop shipped from TR) and I had a conversation with the owner about all this, including the key points about my very spirited daily commute. He's going to check the alignment set-up and advise. I don't know whether the car is set up on stock settings or something else by previous owner/lease. If it's not stock, we'll discuss. Otherwise we'll leave it.
    I'll report back in a day or so.
    I'm excited to have new rubber, esp. the latest, greatest from Michelin.
    Apr 2015
    SoCal
    583
    65
    135
    My front has a lot of neg camber -2.6* and tire wear was generally very even. I hit a pothole here in the golden state and it loosened things up. All of a sudden I was wearing the inner shoulders rapidly. The pothole jolt induced toe out and that was causing the uneven wear. All fixed now but my wallet feels lighter somehow...
    2009 Cayman 2.9L PDK with a few tweaks
    PCA-GPX Chief Driving Instructor
    Jan 2016
    374
    42
    85
    Quote Originally Posted by cajundaddy View Post
    Bingo, basically!
    My alignment was off in a few places, and Toe was wacky: asymmetric and backwards. I don't have the experience to know how important the small errors were, but the toe seems significant. I'm not sure how I'll feel it in concert with new tires (probably less quick turning for both reasons) but I'm very happy to have addressed a tire-wear problem at the time of new PS4S. They wrote my (twisty) commute highway down in the box to describe my driving... :-) I should have attached a photo of the G meter.
    Front
    Toe (L/R/Now): 0",-1/32",+1/32"
    Camber: -0.6,-0.8,-0.6
    Rear
    Camber: L/R/Now -1.6,-1.6,-1.5
    Toe: 1/8",1/16", 1/16"
    Jun 2014
    802
    80
    156
    Yep, toe out will cause inside corner wear. As to your commute... spiriting driving is OK, but public roads are not a DE and you should never intentionally be pulling anywhere close to 1G, please keep that on the track.
    Sep 2006
    786
    49
    You should be good to go now. You will enjoy the Pilot's.
  18. Remove Advertisements
  1. Replies: 35
    Last Post: 07-09-2018, 04:10 AM
  2. Replies: 0
    Last Post: 08-31-2017, 09:00 PM
  3. 981 what causes the brown/golden color stains on the inside of the rims
    By ajahearn in forum Porsche Care and Detailing
    Last Post: 08-12-2017, 12:48 PM
  4. Scalloping on Inside Right Front Tire
    By Road Runner in forum Porsche Tires & Wheels
    Last Post: 10-27-2011, 02:56 PM
  5. Replies: 0
    Last Post: 11-18-2006, 01:49 PM
