718 Boxster tire life?
Results 1 to 16 of 16
Thread: 718 Boxster tire life?
    Dec 2018
    I have a 2017 Boxster w/ automatic and 19" Boxster S wheels, equipped with Yokohama Advan Sport V105 tires.
    I'm on my second set of rear tires and seeing about 7500 miles of life per set. The fronts will probably be worn out soon at 15,000. I drive the car very conservatively...basically just normal city driving. Seems ridiculous to me but could this be normal? If not, what should I do to diagnose?
    I'll be needing four new tires soon. Is the Pilot Sport 4S a good option for someone looking for more tire life?
    Jan 2016
    Houston, TX
    227
    34
    Re: 718 Boxster tire life?
    It would be very helpful to know where you live / what kind of weather you drive in.
    7500 for summer max performance rears is not horrible, and 2:1 rear to front seems to be the norm for our cars.
    If you are not pushing the car (and no track or AX), you could consider A/S with a higher tread wear which will give longer life. Tirerack.com lets you input your car and see all the options - worth looking at the choice and comparing tread wear ratings, reviews, price, etc.
    HTH,
    Tom
    2013 Boxster S
    2018 Q3, 2010 XC70, 2001 Wrangler
    2014 Moto Guzzi Stelvio
    Oct 2016
    NJ
    711
    89
    251
    I have to agree with the OP, 7,500 miles from a set of rear tires that have been driven conservatively is ridiculous.
    I have a 2016 CGTS with 17,500 spirited miles and the OEM GoodYears need rear replacements as they’re at the wear bars. The fronts have approximately 4/32 nds of tread left.
    Are your tires wearing evenly?
    Are you running recommended tire pressures ?
    Dec 2018
    Thanks Tom.
    I'm in South Florida. Long periods of sun interrupted by torrential rains. Tirerack is where I saw the PS4S with pretty good tread wear ratings (300), second only to Continental Extremecontact Sport (340). Neither of which is N spec, but I don't think we really drive like we need an N spec tire. Just an occasional driver, used more when the top can be down comfortably.
    Dec 2018
    Quote Originally Posted by Jim137a View Post
    Yes, pretty even wear...from tire to tire and across each tire. And yes, tire pressures as prescribed.
    Mar 2017
    South Australia
    233
    60
    Maybe your right foot isn't as conservative as you think it is.
    These are all very soft, very sticky tyres and they wear quickly when the 'sticky' is used. On the track a couple of thousand miles is excellent wear. F1 cars can sometimes get close to 150 miles on a set of tyres!
    As far as what tyre is best there are plenty of reviews, summaries and links here: Tyre reviews, tests and ratings - Tyre Reviews
    In one recent test the difference between the best summer performance tyre and the worst was just over 3%.
    BTW--I drive with some spirit multiple times per week and at 21000km (13,000mi) my PZeros are coming close to the wear bars, so not many '000s left. The front and rear are almost identical.
    Sep 2008
    CALIFORNIA
    380
    62
    93
    My Yokohamas are at 10K and have plenty of rubber left. But will likely go with the Michelins when it's time for replacement. Loved them on my 987.
    2006, 987 S, Guards Red, 135K Miles to
    2018, 982, Miami Blue, ...
    2012 Cayenne S, Black
    Aug 2017
    Ohio
    179
    44
    I'm on the same tires as OP and have probably closer to 10k miles on my Yokohamas (I have 17500 on the car, but I swap in winter) - the rears are basically ready for replacement (they might last a month at best in spring). I've done 1 track day in them as well.
    7500 is pretty low mileage to get on them, but depending on road surface / temperature it seems plausible. For any "max performance summer" tire (what comes stock on the car) anything over 10000 miles is pretty decent tread life.
    Instead of paying to swap twice, I'll be getting Michelin PS4s come spring time - they're just all around a better tire.
    2017 718 Cayman - GT Silver, Black/Bordeaux Red, PDK/PSE/Sport Chrono
    Sep 2015
    Atlanta GA
    964
    76
    276
    The factory Bridgestones on my 981 lasted about 12,500 miles on the rear. My current MPSS have about 9,000 miles on them and are wearing much better than the factory tires. I'm estimating I will get 15-17K out of them. 7500 for normal street driving seems crazy low to me. It's completely normal for the fronts on these cars to last as much as twice the miles of the rears for street only driving
    Dec 2018
    Thanks for the feedback everyone. I guess I'll get an alignment once the new tires go on just to eliminate that variable.
    As far as tire pressures go, I've been using the specs on the plate inside the door, 29/30 PSI Front/Back. Does that seem right?
    Dec 2016
    816
    467
    211
    First off you could dump the Yokos which have a UTQG wear rating of 240 and buy a set of Mich Pilot 4S which I believe have a wear rating of 300. In addition to the higher wear rating the 4S have a treadwear warrantee of 30K miles whereas your Yokos have none. As others have said a two to one front to rear milage is about right but 7500 miles for "conservative" driving means you maybe throwing money away.
    Sep 2015
    Atlanta GA
    964
    76
    276
    Quote Originally Posted by RickH View Post
    Just a clarification, the treadwear warranty on any tire is based on rotating the tires on a designated schedule as far as I am aware, so this will not apply to our asymmetrical front/rear tire sizes unless I am missing something? I have always been told by my tire shop that the tread wear warranty on unidirectional tires on my Porsche does not apply since they cannot be rotated up front, or at best will be 50% of the stated warranty value which in the OP's case would still be double what he is currently reporting.
    Jan 2016
    Houston, TX
    227
    34
    Quote Originally Posted by ICNU View Post
    Correct, the mileage warranty for staggered Michelins is 15k miles. If you only get 7500, Tirerack will refund your credit card the prorated purchase amount - I just went through this with some Contis that were warrantied for 50k and were at 2/32 at 24k - I got half refunded and promptly bought Michelins (for the Volvo). No rotation required on staggered, though I still alternate sides occasionally.
    2013 Boxster S
    Dec 2016
    816
    467
    211
    You are correct the milage warrantee does not typicaly cover asymmetrical tires. But what I was thinking is a company willing to warrantee there tires milage surely feels they have a product they can stand behind. The prime reason I gave up PZeros years ago is because I could not get any decent miles on them. Don't get me wrong they may not be as good as the 4S but they are good tires. But they wear like eraser heads. lol
    Jun 2015
    47
    120
    Turbo cars will do that to ya!
    I have put spirited, 20K miles of street driving on Michelin PS4S and still have 5mm all around with my 2.7. Wonderful tire too, I recommend them.
    I used to drive big torque cars, various biturbed gas and diesel. You end up using more rear tire than anything else...
    101
    199
    I have a 981S and will assume the 718 should be in the same ballpark. I got over 15K from my last set or rears (Goodyears from prior owner). On my 987S I'd get 15-20K on the rears.
    Add another recommendation for Michelin Pilot Sport 4S. Great tire, much nicer than the Goodyear I had before this. It seems to be the best all around summer tire from what I read (works fine in rain for me as well).
    Since you are seeing wear issues I'd have it aligned (front and rear) and the suspension checked for issues. Get that done by someone who knows these cars, ideally.
    2015 CS, Carmine Red, PDK, PASM, SC, 20" Carrera S Wheels in Platinum Satin, Premium Package Plus (Entry&Drive, etc), Power Steering+, PDLS, 18 way Sport Seats, ACC, Rear Wiper!
    Previously 2008 CS, Cobalt Blue, PASM, Stone Grey, Sport Seats, ACC, Bi-Xenon, Sport Steering Wheel, Park Assist, Sport Exhaust Tip, Fire Extinguisher, Rear wiper
  19. Remove Advertisements
  1. Replies: 0
    Last Post: 12-05-2018, 11:00 AM
  2. Replies: 0
    Last Post: 08-22-2018, 04:22 AM
  3. Replies: 0
    Last Post: 08-21-2018, 12:30 AM
  4. Tire Life of Pilot Sports
    By Donelonpc in forum Porsche Tires & Wheels
    Last Post: 01-08-2008, 06:51 PM
  5. expected tire life?
    By Caydoc in forum Porsche Tires & Wheels
    Last Post: 02-07-2007, 08:51 AM
