Tire question
Results 1 to 5 of 5
Thread: Tire question
    Mar 2016
    Ohio
    231
    49
    Tire question
    I have been using Bridgestone Re 1's on my 19 inch wheels
    Front are 245-35-19
    Rears are 275-35-19
    i miss Nitto NT 01's but they do not have the same sizes available the nearest they have is
    Front 235-35-19
    Rears 285-35-19
    Have a few questions :
    1. will i notice a big difference with the smaller tires in front ?
    2. will the 285-35-19's fit in the rear with no issue ?
    3. Because the sizes are so different will that kick off any warnings do to size differences ?
    does anyone use this combination of sizes ?
    thanks in advance for any help on this
    2016 Cayman GTS Rhodium Silver Metallic Black Leather delivered 7/11/2016
    pdk, pasm, ptv, adaptive sport seats 18 way, seat ventilation, park assist front and rear, bose surround, power folding side mirrors, sport design steering wheel, aluminum interior package, delete GTS on side, convenience package, door sill guards in stainless steel, seat belts silver grey, center console in aluminum, fire extinguisher
    MODS
    Gt3 front sway bar, Tarret rear sway bar,Expel Ultimate, Ceramic Pro, Led Clear Lights, Zunsport Black Front and Side Grills
    2002 BMW M5 Imola Red, Black Interior
    2016 Toyota Highlander Limited
    1997 993 Triple Black Cabriolet gone but not forgotten
    Dennis
    Oct 2016
    North Carolina
    82
    Re: Tire question
    Dennis:
    Check the diameters of the 235/285 but I'm guessing this combination will be fine. The stock 20" diameters are 26.5"F and 27.3"R. I have run the following combinations on my 2014 CS at VIR with no issues. Yes there are minor handling characteristic changes but once you adapt all is good.
    235/265-20's (P Zero street), 255/650/19 305/690/19 (slicks), 235/645/19 255/650/19 (slicks), 245/645/18 305/680/18 (slicks)
    2018 991.2 GT3 GT Silver
    2014 981 Cayman S Dark Blue Metallic
    2009 987.2 Cayman S Black
    2012 997.2 911 GTS Guards Red - SOLD
    2016 GT4 Sapphire Blue - SOLD
    2016 GT4 Black - SOLD
    2011 GT3RS Grey/Black - SOLD
    2011 987.2 Cayman S White - SOLD
    2008 Boxster RS 60 Spyder - SOLD
    2006 4S Cab GT Silver - SOLD
    Aug 2018
    Dahlonega, GA
    220
    62
    Re: Tire question
    Ride quality in the front will seem a bit worse with the shorter sidewall and you'll have less tire flex going into the corners. The side wall construction of the tire and air pressure can adjust for varying tire flex.
    More rubber in the rear and less rubber in the front may make the car more prone to understeer from what you're currently used to.
    But the biggest concern is how much you're changing the front to rear diameter ratio. Deviating too far from a stock front to rear ratio can upset the ABS balance, which may cause the smaller diameter (fronts) to briefly lock up under hard braking.
    Mar 2016
    Ohio
    231
    49
    Re: Tire question
    Will probably stay with the RE 71's, when i priced them out the NT 01's for a set were $ 200 more not worth it to me . thanks for the information
    MODS
    Dennis
    Sep 2006
    786
    49
    Re: Tire question
    For a street/trackable tire they are the best that we have tested.
  8. Remove Advertisements
  1. A Note on Tire Dressing/ Tire Shine
    By DetailDan in forum Porsche Care and Detailing
    Last Post: 09-27-2012, 05:26 PM
  2. If you were a tire for beginners, which tire would you be?
    By Shiftgood in forum Porsche Tires & Wheels
    Last Post: 06-04-2011, 01:55 PM
  3. persistent low tire pressure on new tire !
    By amsterdam02 in forum Porsche Tires & Wheels
    Last Post: 04-05-2010, 01:44 PM
  4. Tire Rack tire rack
    By SGF in forum Porsche Tires & Wheels
    Last Post: 09-12-2009, 07:48 AM
  5. Porsche Parade Tire Tech session: tire dressings
    By beez in forum Porsche Care and Detailing
    Last Post: 02-25-2007, 11:06 PM
