285/35R19 tire on a 19x10 et36 wheel for a 987.2. Will it work?
Results 1 to 4 of 4
Thread: 285/35R19 tire on a 19x10 et36 wheel for a 987.2. Will it work?
    Mar 2016
    Maryland
    I hope this is not a double post as I can't find my initial post that I swear I just posted.
    I am getting wheels for my car but I am stuck on the tire size for my new wheels in the rear. I will get getting a 19x10 ET 36 wheel. I want the best wheel protection via width and sidewall height so I wanted to run a 285/35R19 tire. I have only really seen this mentioned once on the forum and most people have opted for a 285/30R19. I really want the extra sidewall height to protect my wheels so if anyone has any advice I would appreciate it. I just want to make sure it will fit okay. If I have to, I would not mind going down to a 9.5" rear wheel if that means I could run a 275/35R19 tire. I don't mind any handling changes it will make such as understeer etc. I just want max wheel protection and a beefier tire look on 19's.
    Jun 2016
    IL
    59
    Re: 285/35R19 tire on a 19x10 et36 wheel for a 987.2. Will it work?
    Not sure on the 285's but I have 275's on mine and no issues and worked flawless at Road America last year with no rub issue's
    285/35R19 tire on a 19x10 et36 wheel for a 987.2. Will it work?-2018-05-26-12-cayman-black-wheels-1-jpg
    285/35R19 tire on a 19x10 et36 wheel for a 987.2. Will it work?-2018-05-26-cayman-wheel-redo-275s-245s-2-jpg
    285/35R19 tire on a 19x10 et36 wheel for a 987.2. Will it work?-2018-05-26-cayman-wheel-redo-275s-245s-3-jpg
    Martin MJ
    2012 Cayman R
    www.garagescene.net
    Jan 2008
    828
    49
    I'm somewhat close to your idea.
    I did 285/30x18 et 54 with 15mm spacer 54-15=39
    By extra sidewall protection I guess are talking rim to ground clearance. This should be fine. 9.5 doesn't help with this protection but would give more clearance against curbs. As the tire pushes out more.
    Augie
    Oct 2015
    OREGON
    287
    122
    49
    I run 285/35/18 NT05s on the street with 18x10 ET36 Apex wheels. You'll probably need some negative camber but should work fine.
  7. Remove Advertisements
  1. NEW Concave Mesh 19x8.5 & 19x10 808-Series
    By Wheel Dynamics in forum 987 Cayman and Boxster Modifications
    Last Post: 07-07-2012, 10:23 AM
  2. Michelin Pilot Sport PS2 265/35R19
    Last Post: 01-25-2012, 01:40 PM
  3. SINGLE Bridgestone Potenza RE050A 265/35R19 (9/32, 90% tread)
    Last Post: 04-27-2011, 06:40 PM
  4. SINGLE Bridgestone Potenza RE050A 265/35R19 (90%, 9/32)
    Last Post: 04-27-2011, 06:30 PM
  5. Pair of Toyo Proxes T1R 235/35R19 (7/32, 50% tread)
