981 981 11" wheels
Results 1 to 4 of 4
Thread: 981 11" wheels
    Jan 2017
    UK
    981 11" wheels
    Hello,
    Please can someone help me to check if the following will fit a 981 Boxster without spacers.
    I have standard suspension, no PASM.
    2x Front Wheels – 9jx20 ET55 (235/35/20)
    2x Rear Wheels – 11jx20 ET52 (295/30/20)
    Thank you in advance.
    Jan 2018
    Re: 981 11" wheels
    Re: 981 11" wheels
    Can’t speak to the fronts but I run 19 x 11 et50 rear and it requires a 7mm spacer to clear the strut and rear toe link. On a 20” rear you should?? clear the toe link but I would be concerned about the strut clearance. Not sure why you wouldn’t run spacers with longer wheel bolts.
    Peter
    Jan 2017
    UK
    Re: 981 11" wheels
    Thank you.
  7. Remove Advertisements
  1. Replies: 35
    Last Post: 07-09-2018, 04:10 AM
  2. Replies: 4
    Last Post: 04-06-2013, 10:43 AM
  3. Front: 19" x 8" 57mm Rear: 19" x 11" 51mm
    By sho-one in forum Porsche Tires & Wheels
    Last Post: 02-24-2013, 10:55 AM
