Macan Tire Patching - recommend a repair shop?
Results 1 to 8 of 8
Thread: Tire Patching - recommend a repair shop?
    Jun 2019
    Georgia
    I live in Canton, Georgia (North GA) and I'm new to the area. I'd like to take my Macan someplace for a tire patch. I have a very slow leak. I'd rather not take it to the dealership. I have found a Porsche repair shop that seems good, but this is just a tire patch. Also, I don't want to be told I need, not one, but two new tires, since the leak is in my sidewall and they can't fix it. (Maybe that will be the case, but ...) I was cautioned by my husband about about ruining the brakes because they don't use a torque wrench. So basically, some place that knows what they're doing on a Porsche and is more reasonable than the dealership.
    Aug 2015
    Ontario
    1,788
    525
    763
    Re: Tire Patching - recommend a repair shop?
    Quote Originally Posted by ga-lbj View Post
    It isn't just a tire patch. Sidewall damage is very different from tread damage, and you might have a hard time finding anyone that will even try it.
    I would be looking for new tires. At least two of them.
    2016 CS, Guards Red, Black Interior, 20" Carrera S partially black, PDK, Sport Chrono, SportDesign Steering Wheel, Sports Seats +, PDLS with HBA, Convenience, Red Belts, Bose, SS sills illuminated, Wailing NA flat 6!
    Mar 2009
    2,147
    825
    611
    Quote Originally Posted by OttawaSteve View Post
    Plus one on this comment. Tire shops will not patch a sidewall for many reasons, the most important of which is liability when it doesn't do the job and causes an accident. However depending on how many miles you have on the tires, you could get away with buying just one. My own rule of thumb is if the tires have less than 5K or so miles on them, buying only one tire will be fine.
    Oct 2016
    NJ
    710
    89
    251
    Sidewall damage should not be repaired. If you find a shop that says they’ll fix sidewall damage - RUN. There’s a lot of stress and flexing going on in the sidewall.
    https://youtu.be/WxnkGiAOOhM
    Attached Thumbnails Attached Thumbnails Tire Patching - recommend a repair shop?-c933890f-2ff7-4fa6-9236-31c79974bb78-jpg
    Mar 2015
    374
    163
    108
    Are you actually saying you know the leak is in your sidewall or are you concerned they will tell you that in order to sell you new tires?
    2014 Base Cayman, M/T, Rodium Silver, Agate Grey/Amber Orange interior, Sport Wheel, Power Folding Mirrors, Bose Infotainment...
    1,551
    104
    257
    Patching a tire is a straightforward repair. Any reputable tire shop e.g. Discount Tire, etc.can do it, and will be able to determine whether or not it is safely repairable, as shown in the previous post. Just insist they use a torque wrench with a soft socket to tighten the lug bolts to factory specification. The repaired tire should also be balanced.
    If the tire is not repairable, then you'll need to decide if one or two new tires is required. Generally speaking, if the opposite side [good] tire is worn ~50% or more, you should consider replacing both tires. You'll ideally want to stay with the same make, model, and N specification tire as originally installed, or update one or both tires to the next higher N designation. If the tire(s) need to be ordered, a reputable shop can temporarily install a used replacement tire to function as a spare until the order arrives. Just stay off the autobahn or race track until the mismatched tires are replaced.Tire Patching - recommend a repair shop?
    Best regards,
    Croc'ed
    Jun 2019
    Georgia
    I asked a Porsche enthusiast friend. He said that Mavis Tire (formerly Kauffman Tire) was a reliable shop. There are several locations near me in North Georgia. If I do need new tires, I will definitely buy them. However, I don't want to buy a tire if a patch is sufficient.
    Jan 2017
    MD
    225
    676
    Gamertag: beavanjb
    Can afford a Porsche Macan but can't spend $250 on a tire? At least buy a $100 used tire, I've done this a few times for our Cayenne and they work perfect. If your husband doesn't understand the importance of tires then file for divorce.
    Sent from my SM-G960U using Tapatalk
    2013 Porsche Boxster S, Guards Red, 6-speed, 19" S wheels, Sport Chrono, PASM, PTV, AP Exhaust, AP Sport headers, BMC air filters, IDP Plenum with 82mm throttle body, Cobb Accessport and Pro Tune.
  11. Remove Advertisements
