1 - 2 of 2 Posts
Any advice or experience on whether these wheels will fit on my 2012 Cayman? Fronts are 18x7.5 with 50 offset, rears are 18x9 with 52 offset.
These came off of a 2000 Boxster, if that helps.
thanks.
The wheels you're considering are most likely narrower than what you already have on the car but the offset and width should allow you to fit (bolt-on) the wheels. Depending on what your goals are, you might consider adding spacers as they will be more sunken into the wheel well relative to factory stock wheels.
1 - 2 of 2 Posts
