I'm flying from NC to Orlando tomorrow to pick up a 2006 Cayman S with 42,000 miles. Car had 40,000 mile service at 37,800 miles in Feb. No apparent problems. Just had PPI by the same shop and showed a code of driver side cooling fan inop. So failure likely occurred in past few months. I'm having shop put on new tires and align. They quoted me $687 for a fan replacement. My question is whether this year Cayman/Boxster had a fan resistor, since these are a regular failure item ($100 item vs $400+). I've seen conflicting answers to this (2006 different from 2007?). I'm willing to pay for the repair if it's likely the problem. Given the cost of a new fan, labor in this case is not horrible. I also had suggested to me that this failure is random and somewhat premature and I can get a tested used fan for about $200 and install that. It appears to be a fairly easy DIY. I'm planning to bring the car back to NC and have been assured by several owners that the car will be fine on the trip (essentially all interstate), and I should be able to swap out the fan after testing to be sure it's the issue.
Any comments, hints, references welcomed.
Thanks.
Thanks.
