Year:2006
Make:Porsche
Model:Cayman
Mileage:43500 M
Transmission:Manual
Engine:3.4L
Trim:S Sport Chrono
2006 Cayman S Sports Chrono
No lien. Clean title.
Full Gallery here 2006PorscheCaymanS - Google Drive
Scrape on the front center of the lower lip.
The previous owner garaged for winters.
- 2 oil changes with Blackstone results
- DME screenshots of over revs report
- No codes or CELs
- Exterior: Seal Grey Metallic
- Interior: Black Sport Seats
- 342 Heated Front Seats
- 403 19" Carrera S Wheel
- 446 Wheel Caps with Colored Crest
- 573 Automatic Climate Control
- 639 Sport Chrono Pkg W/Out PCM
- 680 Bose Surround Sound System
- AP Black Sport Seats
- M6A Black Mats - Porsche lettering
- P01 Adaptive Sport Seats
- P74 Bi-Xenon Headlamp Package
- X70 Metal Door Sill Model Insignia
- XCZ Sport Shifter
- Water pump was replaced
- Headliner replaced
- Continental Extreme Contact <8k miles. One rear has a patch, which was due to a small construction staple and is a proper patch not plug
- Passenger tie rod inner/outer (was failing)
- AOS (did not fail, preventative)
- Porsche Engine Oil Pressure Relief Valve (did not fail, preventative)
- Coils/plugs (did not fail, no codes, preventative)
- Starter (was failing)
- Brake fluid flushed/parking brake adjusted
- Gear oil replaced
- New horn (old one failed and was weak)
- New wipers
- Battery
- Cabin filter
- Koni Yellow with Eibach Pro Springs, new top mounts. With alignment.
- 2 car covers indoor and outdoor
- 17” winter wheels with 2 new front tires (purchased and used under this ownership)
- New Weather Tech driver and passenger (original Porsche mats as well)
- Front and rear Porsche liners (frunk/hatch)
- Clear OEM sides (stock orange and aftermarket smoked LED included with sale)
- Interior Leds
- Extra set of spark plugs
