Well I got by Stock Base run done this morning and got 259.42 HP/222.32 Ft-Lbf of Torque at the wheels, on a Dynojet Research Dyno.
Run Conditions:
Temperature 58.33 F
Barometric Pressure 30.02 inches Hg
Humidity 44%
SAE 0.96
Vehicle Condition: Fuel - Chevron 92 Octane, fresh oil change, wheel alignment, and brand new 19" Bridgestone RE050A tires.
At an approximate 15% power loss through the powertrain to the engine, the engine is putting out around 305.2 HP.
260-265 on a DynoJet is pretty typical of a stock Cayman S for your year, so you are right there. I started with 267 on a Mustang dyno and I believe 264 or 265 on a DynoJet dyno when stock.
Thanks.
I just installed the Dream1 Exhaust Accumulator w/a Sport Exhaust Tip today. I'm going to check that out on a Dyno, though I don't expect much.
Future mods: Cat back exhaust (Borla?), w/maybe a header system, Limited Slip Differential, Softronic Software, and maybe a GT3 throttle body
What are you putting out now w/all your modifications on your 06 CS?
