I have a 2007 Cayman S with 41,000 miles on it. I have a Borla catback exhaust with stock headers/cats. For the past year the car has been throwing a P0421 which is a catalyitic converter warm up error. I swapped the secondary O2 sensors from left to right and it still threw the same code. Its now to the point that when I clear the code it comes back very quickly. It used to take a couple hundred miles.
That leads be to believe that if the secondary sensors were bad it would have switched to a P0431 code.
I think the car has a slightly stronger smell to it only noticeable at startup when backing up. Is it safe to assume that the cats (or at least one) are going bad? Car runs great still.
If this is the case, I am looking for suggestions on what I should do about the cats? Magnaflow makes what they call an OEM Grade Exhaust Manifold with Integrated Catalytic Converter which is only about $400 each.
I am concerned that will be a short lasting part.
Is it worth it to go with something like the Fabspeed 200 cell sport headers at $2800 for the pair? More exhaust note would be welcomed, the borla exhaust sounds awesome as is, and probably even better with more flow.
