1 - 2 of 2 Posts
Anyone ever had abs tire sensor go bad. I have one that needs to be replaced . I have 79k on my 2010 Panamera S. I am curious if all of them will go out about the same time. If they fail it will shut your entire vehicle down. Chassis, PSM, ABS failure all at the same time.
If you really mean ABS sensor instead of TPMS (Tire pressure), then, yes it is likely to trigger a number of failure warnings. The ECU uses ABS sensor data for a number of systems. It is unlikely the rest will go bad.
Have you had any brake work done on the car? Maybe the connection to the sensor came loose.
1 - 2 of 2 Posts
