Hi,
I've been seeing this annoying gem for months, and have scoured the interwebs for a cure, to no avail.
Using a cell phone w/ flash, I have been able to determine power to the sensors.
  • I had a V1 tucked quite tightly just below the mirror to the right of the mount and figured this may have bumped the harness, but haven't found a tutorial to pull apart the relevant pieces of the mirror to check the connection.
  • Additionally, I had thought that the V1 powered via concealed RJ11 up the A-piller and across may be causing interference, but with the V1 removed and cable moved out of the way, the issue remains.
Any thoughts / bumps in the right direction to rid myself of the annoying error?
Thanks much in advance!
