1 - 11 of 11 Posts
Don't assume the TSBs will be covered out of warranty. I had a Highlander with a TSB for belt tensioner that was only covered during the car's waranty period. I had to pay for the fix.
What are these TSB's for? I never had a complaint that resulted in a TSB being applied.
STEERING:ELECTRIC POWER ASSIST SYSTEM
TSB #TI-40-13
NHTSA ID #10055681
Date Announced:
APRIL 28 2014
Additional Info:
How to Fix
Summary: PORSCHE: ON SOME VEHICLES, THE STEERING WHEEL ELECTRONICS OR CONTROL UNIT FOR STEERING COLUMN SWITCH WOULD HAVE A MALFUNCTION, DURING CODING, IN HEATED STEERING WHEEL, ON BOARD COMPUTER, CRUISE CONTROL OR MULTI-FUNCTION STEERING WHEEL. MO
More Information »
SERVICE BRAKES, ELECTRIC
TSB #TIS-10-13
NHTSA ID #10052226
Date Announced:
APRIL 08 2013
Additional Info:
How to Fix
Summary: PORSCHE: ON SOME VEHICLES, WITH 6 SPEED MANUAL TRANSMISSION, THE ELECTRIC PARKING CONTROL BRAKE UNIT HAS IMPLAUSIBLE FAULT ENTRIES DUE TO MONITORING FUNCTION IS TOO SENSITIVE AND NEEDS TO BE REPROGRAMMED. MODELS 2013-2014 BOXSTER (981),
More Information »
SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:MASTER CYLINDER
TSB #TI-4-14
NHTSA ID #10055359
Date Announced:
MARCH 21 2014
Additional Info:
How to Fix
Summary: PORSCHE: INFORMATION PERTAINING TO A VOLUNTARY WORKSHOP CAMPAIGN TO REPLACE THE RETURN LINE ON THE CLUTCH MASTER CYLINDER. MODELS INCLUDE: BOXSTER (981)/BOXXTER S (981) MODEL YEAR: 2013. *JS
More Information »
ENGINE (PWS)
TSB #TI-43-12
NHTSA ID #10044663
Date Announced:
JUNE 27 2012
Additional Info:
How to Fix
Summary: PORSCHE: THE RELAY SETTING FOR ENGINE COMPARTMENT BLOWER FAIL TO BE INSERTED CORRECTLY IN RELAY CARRIER AND WARNING SHOWN IN MULTI FUNCTION DISPLAY. *PE
More Information »
TSB #WC-07-03-12
NHTSA ID #10044999
Date Announced:
JUNE 27 2012
Additional Info:
How to Fix
Summary: PORSCHE: RELAY FOR ENGINE-COMPARTMENT BLOWER. THERE IS THE POSSIBILITY THAT THE RELAY FOR SETTING 1 OF THE ENGINE-COMPARTMENT BLOWER IS NOT INSERTED CORRECTLY IN THE RELAY CARRIER ON THE AFFECTED VEHICLES. *JS
More Information »
FUEL SYSTEM, OTHER:STORAGE:TANK ASSEMBLY
TSB #WF77
NHTSA ID #10074885
Date Announced:
FEBRUARY 16 2016
Additional Info:
How to Fix
Summary: SUMMARY TO BE PROVIDED ON A FUTURE DATE.
More Information »
ELECTRICAL SYSTEM
TSB #TI-59-14
NHTSA ID #10056345
Date Announced:
AUGUST 07 2014
Additional Info:
How to Fix
Summary: PORSCHE: ACCORDING TO NEW SOFTWARE, (VERSION 2900), FRONT END ELECTRONIC CONTROL UNIT (FRONT BCM) MUST BE FLASHED, IF REAR END ELECTRONICS CONTROL UNIT (REAR BCM) NEEDS REPLACING. MODEL 2013-2014 911 991), BOXSTER (981), CAYMAN (981).
More Information »
TSB #TI-12-11-13
NHTSA ID #10054518
Date Announced:
DECEMBER 11 2013
Additional Info:
How to Fix
Summary: PORSCHE: INFORMATION CONCERNING THE PROCEDURE FOR REPROGRAMMING THE PDK CONTROL UNIT. BOXSTER (981)/BOXSTER S (981) AND CAYMAN (981)/CAYMAN S (981). MODEL YEARS 2013-2014. *JS
More Information »
ELECTRICAL SYSTEM:IGNITION
TSB #TI-58-12
NHTSA ID #10055907
Date Announced:
MAY 16 2014
Additional Info:
How to Fix
Summary: PORSCHE: PROCEDURAL INFORMATION PROVIDED REGARDING THE REPLACING OF FAULTY CRACKED IGNITION COILS ON CERTAIN VEHICLES. MODEL 1997-2013 BOXSTER (986), BOXSTER/CAYMAN (987), CARRERA (996 & 997). *PE
More Information »
ELECTRICAL SYSTEM:IGNITION:SWITCH
TSB #TI-9-13
NHTSA ID #10052188
Date Announced:
APRIL 19 2013
Additional Info:
How to Fix
Summary: PORSCHE: ON CERTAIN VEHICLES, THE START STOP FUNCTION CANNOT BE ACTIVATED USING CENTER CONSOLE BUTTON DUE TO BEING DEACTIVATED AT TIME OF MANUFACTURING, AND NOT RE-ACTIVATED AFTERWARDS AND MUST REPLACE DME CONTROL UNIT. MODELS 2013-2014 B
More Information »
ELECTRICAL SYSTEM:IGNITION:MODULE
TSB #TI-9-13
NHTSA ID #10052188
Date Announced:
APRIL 19 2013
Additional Info:
How to Fix
More Information »
DIGITAL INSTRUMENT PANEL
TSB #TI-2-14
NHTSA ID #10055657
Date Announced:
APRIL 15 2014
Additional Info:
How to Fix
Summary: PORSCHE: INSTRUMENT CLUSTER SOFTWARE NEEDS REPROGRAMMING DUE TO DISPLAYING INCORRECT INFORMATION AND CAN STOP WORKING OR WILL WORK, AFTER CERTAIN CONDITIONS, ON SOME VEHICLES. MODEL 2012-2014 BOXSTER, CAYMAN, 911. *PE
More Information »
ELECTRICAL SYSTEM: SOFTWARE
TSB #TI-59-14
NHTSA ID #10056345
Date Announced:
AUGUST 07 2014
Additional Info:
How to Fix
More Information »
TSB #TI-2-14
NHTSA ID #10055657
Date Announced:
APRIL 15 2014
Additional Info:
How to Fix
More Information »
STRUCTURE: FRAME AND MEMBERS:UNDERBODY SHIELDS
TSB #TI-7-13
NHTSA ID #10052000
Date Announced:
MARCH 26 2013
Additional Info:
How to Fix
Summary: PORSCHE: THE WATER DRAIN VALVES ARE BLOCKED DUE TO AN INCORRECT PARAMETERS PROCESS USED WHEN APPLYING CAVITY SEALING AND FAILED TO DRY COMPLETELY. MODEL 2013 BOXSTER (981), BOXSTER S (981). *PE
More Information »
I assume even though my car is out of warranty, I can still get the TSB's taken care of.
I would guess there is good chance Porsche would take care of any fix addressed by a TSB, if your car actually has the problem addressed by the TSB. If you are asking if you could go to the dealer and have them just blanket do all the TSB's, then the answer is no. It is a TSB, and not a recall, because it only affect some vehicles.
My car was built on the 21st of March 2016, I'm hoping I don't have a whole lot to look forward to!
I've got a 2013BS under a cpo warranty. The only thing I noticed was the auto start/stop never works. No idea if it's because of a defect or conditions.
Other than that, the car has been rock solid for 31k miles.
About half of them are just software reflashes, it looks like.
Just be glad you didn't buy a first-year C7 Corvette. :crazy:
Dealers apply required TSBs during routine maintenance. In 2014 when I brought my car in for its first oil change, the SA told me that they applied one. When I took my car in for its last service under warranty, I asked the SA to apply any TSBs that affected my car. He told me that there were none. So to the best of my knowledge only one of these TSBs were applied to my car.
1 - 11 of 11 Posts
