1 - 3 of 3 Posts
Hi Folks
Does anyone know the rev ranges for the 981 Cayman and Boxster GTS?
I believe a hard limiter exists at 7800 rpm, so I assume range 1 is 7800-7900?
Hi Folks
I could look them up on my computer but it is being used; if memory serves me correctly, it's usually 200 - 300 RPM above the factory cut. The new 991/981 based 9A1 DFI motors are 7800 RPM across the board for base, S and GTS models. I'm not sure about the 991 GTS but it should be similar. I think that 8K could be the far end of the Stage I range. Cheers!
Many thanks!
1 - 3 of 3 Posts
