I'm wanting to install K&N engine air fiter/filters on my 2015 cayman gts .Can someone supply me with the correct part number so I can make sure that I am initially purchasing the proper part/parts?
K&N part number for my particular application is E-0666. There are two of these required for my vehicle,is this correct? I have never seen the top of my engine so I'm not sure......................PLEASE HELP:dance:
Caymudgeon
I have good news and bad news. Good news: You have the correct part number and you do need qty = 2. Bad News: You still won't see the top of your engine if all you do is install the air filters.:)
There's an excellent video on You Tube where a Porsche mechanic shows how to change the air filters to in a 918 Boxster.
There are a lot of threads on this. Check them out. The big debate is if it is worth the cost until an ECU mapping with plenum and TB upgrades are available.
If you are going to install a K&N (or any oiled filter) make sure to schedule cleaning and re-oiling on a yearly basis. They are not fire-and-forget like a paper filter.
