Recently had to trade my 987-1 in and got a 2018 Cayenne GTS (leg injury stopped manual transmission driving) I have a set of 19" rims with good Yoko Iceguard tires with 5x114.3 (5x4.5") bolt pattern that I'd like to use for the winter. Cayenne has 21" rims 5x130mm pattern. I understand that there are wheel adapters to cater for the bolt pattern change but then there will need to be a change in the speedo etc to produce the correct readings due to rim size change. Any thoughts on 1. whether adapters are a good idea and 2. on the speedo reading change. Thanks
