1 - 8 of 8 Posts
So I picked up a set of four 350mm rotors from a 991 GTS for a song. I’ve googled around a ton, but the answer isn’t clear - can I swap these in on my stock calipers, or do I need upgraded calipers / additional spacers / longer bolts? They’ll definitely clear my wheels, I just haven’t done an exploratory rotor removal and fit yet, and I figure I can save grief by asking here.
I’m only bothering because it’s time for new rotors anyway, so I figure why not upgrade?
Thanks!
I've done this swap already. The base uses a 77mm long bolt. The S uses an 85mm long bolt. You can get them from the dealership / online. Use the longer bolt and a spacer seated between the caliper and the knuckle, and that's all you need.
if you get the Tarrett stud kit it comes with the necessary spacer and is a better setup for brake pad changes going forward. Especially if you may track the car and swap pads often.
Oh, I didn't notice that! I actually have the stud kit, bought it a bit ago knowing I would want to upgrade the brakes when the rotors were shot, so I didn't open the package yet, but that's great news. I did notice it looked a bit bulkier than eight bolts should be.
Thanks all, this is helpful!
actually, my apologies think I misspoke, I just looked again and don't think the Tarrett kit comes with the spacers standard. My bad!!
The Girodisc rotors at 350MM come standard with the necessary spacers. Maybe try contacting them to see if you can just get the spacers.
1 - 8 of 8 Posts
