1 - 8 of 8 Posts
718 Exhaust Dual Tip Install. Is this a simple install?
I really would like to do this myself if possible. Any videos or tips for the 718?
Discussion Starter #2
After my search here on Long Island I finally found a shop and tech that I felt comfortable using. Install was straight forward. I choose to use the FabSpeed X exhaust tip. After the instal I got home decided to paint the inside with a Hi-Temp flat black paint.
This was my first modification. I am really please with my Well Optioned Base 718 however the Stock Oval Tip had to go.
267428
Tech used a drive on lift.
Car is less than a year old so the bolts easily unloosened. First loosened the two bolts on the tip and two bolts on the crossover. Removed the two bolts on the head pipe on drivers side removed the driver side pipe. Removed crossover tube and stock tip. Installed new tip. Replaced head pipe. Lined everything up and tightened.
Hello. I typically do most work but n my cars but this is not easy because both mufflers should be loosened which is hard access without a lift.
I ended paying $100 to have installed at local German indie shop.
Discussion Starter #7
I paid $200 usd
1 - 8 of 8 Posts
